As on the download page.
I am compling at the moment - and will try to figure out how to use it in Myth.
If you have any successes - -please post here
PerryM Wrote:To be clear - I ran the 'make' scripts and did the install, but after the reboot there is still no sign of my card being recognised by MythTV. I know the card works because I did a sneaky Windows install first!
A simple line by line install example assuming NO prior knowledge would be great.
cd Downloads
mkdir Drivers
cd Drivers
wget http://www.tbsdtv.com/download/document/common/tbs-linux-drivers_v120212.zip
unzip tbs-linux-drivers_v120212.zip
tar xvjf linux-tbs-drivers.tar.bz2
cd linux-tbs-drivers
find -type d -exec chmod 755 \{\} \;
find -type f -exec chmod 644 \{\} \;
find -name '*.pl' -o -name '*.sh' -exec chmod 755 \{\} \;
cd v4l/scripts
sudo chmod +x make_myconfig.pl make_makefile.pl make_kconfig.pl rmmod.pl
cd ..
cd ..
./v4l/tbs-x86.sh
./v4l/tbs-x86_64.sh
make
sudo make install
01:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
Subsystem: Device 6280:0011
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at fbe00000 (64-bit, non-prefetchable) [size=1M]
Capabilities: <access denied>
Kernel modules: saa716x_tbs-dvb
dmesg | grep DVB
[ 5.681161] DVB: registering new adapter (SAA716x dvb adapter)
[ 6.381658] DVB: registering adapter 0 frontend 0 (TurboSight TBS 62x0 DVBT/T2 frontend)...
[ 6.381926] DVB: registering new adapter (SAA716x dvb adapter)
[ 6.465764] DVB: registering adapter 1 frontend 0 (TurboSight TBS 62x0 DVBT/T2 frontend)...
