Linux drivers for TBS6925
Postby SergioDanielG » Tue May 31, 2011 3:55 am
Hi. Where can I obtain Linux drivers for TBS6925 card?
Thanks.
SergioDanielG
Re: Linux drivers for TBS6925
Postby warumnix » Tue Jun 07, 2011 10:35 am
Hi SergioDanielG,
you could download the driver here:
http://www.tbsdtv.com/english/Download.html
warumnix
Postby SergioDanielG » Wed Jun 22, 2011 1:52 am
Thanks warumnix, it was published four days after my post.
Tahnks again.
SergioDanielG
Postby johnnyb » Thu Jun 23, 2011 4:08 am
Sergio -
Did you get the driver working? If so what is your build environment, I'm having trouble with unknown symbols in saa716x_core under stock Fedora 15 2.6.38.8.32.
Thanks -
Johnny
SergioDanielG wrote:Thanks warumnix, it was published four days after my post.
Tahnks again.
johnnyb
Postby SergioDanielG » Sat Jun 25, 2011 12:36 am
Yes, it's working with kernel 2.6.39-1 in Debian Sid. And works with kernel 2.6.38-2 too
But with same changes to compile:
Look this, it's part of an e-mail sended to tbs support:
First, linux/smp_lock.h not found.
I put in linux/include/linux/smp_lock.h
#ifndef __LINUX_SMPLOCK_H
#define __LINUX_SMPLOCK_H
/*#include <linux/config.h>*/
#ifndef CONFIG_SMP
#define lock_kernel() do { } while(0)
#define unlock_kernel() do { } while(0)
#define release_kernel_lock(task, cpu) do { } while(0)
#define reacquire_kernel_lock(task) do { } while(0)
#define kernel_locked() 1
#else
/*#include <asm/smplock.h>*/
#endif /* CONFIG_SMP */
#endif
Next error...
v4l/saa7134-i2c.c:342: error: unknown field 'id' specified in initializer
My solution? Comment line 342
/* .id = I2C_HW_SAA7134, */
With this I compile the driver..
Then: checkintall -D (Debian Sid)
But missing directories in linux headers...
#mkdir -P /lib/modules/2.6.39-1-amd64/kernel/drivers/media/common/saa716x/
#mkdir -P /lib/modules/2.6.39-1-amd64/kernel/drivers/media/IR/keymaps/
#mkdir -P /lib/modules/2.6.39-1-amd64/kernel/drivers/media/video/usbvideo/
#mkdir -P /lib/modules/2.6.39-1-amd64/kernel/drivers/media/video/ovcamchip
#mkdir -P /lib/modules/2.6.39-1-amd64/kernel/drivers/media/video/zc0301/
#dpkg --force-overwrite -i linux-tbs_20110601-1_amd64.deb
And... Enjoy!
Can you paste the errors here?
SergioDanielG
Postby johnnyb » Sat Jun 25, 2011 5:32 am
So I'm running Fedora 15 - 2.6.38 - First problem is
/tbs/67/linux-tbs-drivers/v4l/cx25840-ir.c:1254:3: error: implicit declaration of function 'kfree' [-Werror=implicit-function-declaration]
make[3]: *** [/tbs/67/linux-tbs-drivers/v4l/cx25840-ir.o] Error 1
make[2]: *** [_module_/tbs/67/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory `/usr/src/kernels/2.6.38.8-32.fc15.i686'
make[1]: Leaving directory `/tbs/67/linux-tbs-drivers/v4l'
make: *** [all] Error 2
So I comment out in the v4l/.config the line for the CX25840.
make
make install
on reboot (autoload of modules) , or via modprobe:
modprobe saa716x-core or modprobe saa716x_tbs-dvb
FATAL: Error inserting saa716x_core (/lib/modules/2.6.38.8-32.fc15.i686/kernel/drivers/media/common/saa716x/saa716x_core.ko): Unknown symbol in module, or unknown parameter (see dmesg)
dmesg reports:
[93840.740088] saa716x_core: Unknown symbol spi_alloc_master (err 0)
[93840.741103] saa716x_core: Unknown symbol spi_unregister_master (err 0)
[93840.741415] saa716x_core: Unknown symbol spi_register_master (err 0)
That's where I am right now...
lspci -vvv reports:
01:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
Subsystem: Device 6925:0001
Interrupt: pin A routed to IRQ 11
Region 0: Memory at fe900000 (64-bit, non-prefetchable) [size=1M]
Address: 0000000000000000 Data: 0000
DevCtl: Report errors: Correctable- Non-Fatal+ Fatal+ Unsupported-
Kernel modules: saa716x_tbs-dvb
Johnny
johnnyb
