Loss of HD Channels in uk
Postby RingaDing » Tue Jun 07, 2011 7:24 am
Last week the BBC changed to S2 but I am unable to get my reciever to find them from either WMC or TBSViewer.
My dish is OK as I also run a Freesat box from it on a dual lnb which is recieving them ok after a retune.
Please can you help.
Satellite: Astra 2D tp.50
Frequency: 10,847MHz (vertical polarity)
Modulation: DVB-S2, QPSK
Symbol Rate: 23.0
FEC: 8/9
RingaDing
Re: Loss of HD Channels in uk
Postby lewiswoo1 » Thu Jun 09, 2011 1:51 am
Yes i know pain in the arse! Simply go into your wmp/tasks/tv setup/single transponder set up and type in Frequency 10847 , symbol rate 23 and vertical polarity then rescan should sort it.
lewiswoo1
Postby RingaDing » Thu Jun 09, 2011 4:07 am
Thanks for the guide.
alas this didn't do it. Realy don't understand why i'm having a problem. The reciever has been great up to this change from the BBC.
Used Fast Satfinder to check my signal on the 10847 Freq which reports 97 Strength and 83 quality.
Am at a total loss as this effects is in both WMC and TBSviewer.
Perhaps there's a driver issue?
Any body help
RingaDing
Postby steven » Thu Jun 09, 2011 4:54 pm
RingaDing wrote:Thanks for the guide.
Any body help
Hi We wil have a test later ,and give you a answer as soon as possible.
Postby BryanD » Thu Jun 09, 2011 11:13 pm
This is a real pain!!!
I have a TBS 8920 PCI card with the latest driver installed. I use DVBViewer as my viewer and I am now unable to watch either of BBC HD or BBC ONE HD. As I understand it my card supports DVB S2 so why does it not allow me to see either of the BBC HD Channels. Please can somebody help before I am left hairless and injure somebody outside with a flying PCI card. Doing a frequency search does not help and the information provided by the BBC is no better than useless!!
BryanD
Postby BryanD » Thu Jun 09, 2011 11:14 pm
Also meant to say Freesat are singularly unhelpful.
BryanD
Postby RingaDing » Thu Jun 09, 2011 11:20 pm
Thank you steven
Have since re-installed the driver and had success recieving BBCHD/BBC1HD with WMC but no luck with TBSViewer.
Note: Qbox fails to lock. No Green LED
Changing to the new BBC S2 from standard S service is very very slow
Again thank you for help.
RingaDing
Postby lewiswoo1 » Fri Jun 10, 2011 4:51 am
Hi again sorry you seem to still have problems i have the 6981dual tuner card when the problem occured i first tried setting up wmc again doing a standard tv set up then a full transponder scan then a single transponder scan using the settings previously stated . My set up is now working fine again with no problems , maybe it was a combination of all these things . My desktop is nothing special but is newish with windows7. I hope this helps , good luck!
lewiswoo1
Postby BryanD » Fri Jun 10, 2011 4:16 pm
Here is the fix if you are using DVBViewer.
Search for and Edit the 0282.ini files and change the existing 10847 line to
10=10847,V,23000,89,5,|BSkyB, BBC HD
This includes the new parameters 23000, 89, and 5.
A rescan should now find the files.
This was suggested to me by a friend and it worked great.
BryanD
Postby steven » Wed Jun 15, 2011 9:39 am
