Firmware files and another question!!
Postby apx » Mon Jul 05, 2010 11:55 pm
Hello.
I had to install a system from scratch, so I downloaded the drivers from the site.
I have a question, why the new driver package does not contain the firmare files
And another question!
Why I can not run the channel scan MythTV. Whenever I try, I receive error message
apx
Re: Firmware files and another question!!
Postby cody » Tue Jul 06, 2010 10:06 am
hello
apx wrote:I have a question, why the new driver package does not contain the firmware files
thank you for pointing us to this - it's just a mistake. we will fix it shortly.
apx wrote:Why I can not run the channel scan MythTV. Whenever I try, I receive error message
did you install firmware files from previous driver package and the box is functional in other software?
other than that all recent versions of the DVB applications in Linux use the same S2-API to work with DVB-S2 hardware and if other software is functional and MythTV not then it's not driver fault, but somethings wrong with your MythTV installation/settings.
