unable to install Drivers on centOS 6.2
Postby akashif » Wed Feb 29, 2012 7:04 pm
i am unable to install Linux Drivers for my recently purchased tbs6925, i tried to use the drivers from CD shipped with card also downloaded the drivers from http://www.tbsdtv.com/download/ but could me make it.
here is the log
[[email protected] v4l]# uname -r
2.6.32-220.el6.i686
[[email protected] cDrivers]# cd linux-tbs-drivers
[[email protected] linux-tbs-drivers]# ./v4l/tbs-x86.sh
TBS drivers configured for x86 platform.
[[email protected] linux-tbs-drivers]# ls
COPYING INSTALL linux Makefile media-specs README README.patches v4l v4l_experimental
[[email protected] linux-tbs-drivers]# make
make -C /root/root/cDrivers/linux-tbs-drivers/v4l
make[1]: Entering directory `/root/root/cDrivers/linux-tbs-drivers/v4l'
No version yet, using 2.6.32-220.el6.i686
make[1]: Leaving directory `/root/root/cDrivers/linux-tbs-drivers/v4l'
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 2.6.32
File not found: /lib/modules/2.6.32-220.el6.i686/build/.config at ./scripts/make_kconfig.pl line 32, <IN> line 4.
make[1]: *** No rule to make target `.myconfig', needed by `config-compat.h'. Stop.
make: *** [all] Error 2
Need urgent Help.
Ali
akashif
Re: unable to install Drivers on centOS 6.2
Postby SergioDanielG » Wed Feb 29, 2012 8:07 pm
Hi akashif!
Are you sure you have kernel header installed?
You can try disclean before make, too.
Code: Select all
[[email protected] linux-tbs-drivers]# cd linux-tbs-drivers
[[email protected] linux-tbs-drivers]# make clean
[[email protected] linux-tbs-drivers]# make distclean
[[email protected] linux-tbs-drivers] #make
Best regards.
SergioDanielG
Postby akashif » Wed Feb 29, 2012 8:22 pm
i am newb in linux, and i dont know kernel header are installed or not, let me google it, and i will come back to you for further details.
Ali
akashif
Postby SergioDanielG » Wed Feb 29, 2012 8:42 pm
akashif wrote:Hi
Ali
To install kernel headers try
# yum install kernel-devel
Best regards
SergioDanielG
Postby akashif » Wed Feb 29, 2012 9:03 pm
yes i did found on google and did following
1) installed the kernel-devel --> installed successfully
2) Followed your instructions
but still same issue.
unable to attach the text file of full logs , system always says "The extension txt is not allowed."
make -C /root/root/tbs/linux-tbs-drivers/v4l
make[1]: Entering directory `/root/root/tbs/linux-tbs-drivers/v4l'
make[1]: Leaving directory `/root/root/tbs/linux-tbs-drivers/v4l'
akashif
Postby SergioDanielG » Wed Feb 29, 2012 9:18 pm
Wait... lets me remember...
I have a TBS6925 but I can't remember if I use it with kernel 2.6.32, actually I have kernel 2.6.39, 3.0.1 and 3.2.0...
Can you try a previous version like this: http://www.tbsdtv.com/download/document ... 111118.zip ?
I remember there was great changes in kernel versions from 2.6.32 to 3.2..x, the last version of tbs linux driver work of with kernel 3.x, I tried all drivers version, but actually I'm not at home to say you with security... If you can wait 2 or 3 hs, I'll confirme that.
Best regards.
SergioDanielG
Postby akashif » Wed Feb 29, 2012 10:36 pm
Let me try installing the drivers from this , as you suggested. and lets see
will update you soon in this
Ali
akashif
Postby akashif » Wed Feb 29, 2012 10:58 pm
HI
tried the suggested Drives and same result. see the log file
make -C /root/root/oldtabs/linux-tbs-drivers/v4l
make[1]: Entering directory `/root/root/oldtabs/linux-tbs-drivers/v4l'
make[1]: Leaving directory `/root/root/oldtabs/linux-tbs-drivers/v4l'
File not found: /lib/modules/2.6.32-220.el6.i686/build/.config at ./scripts/make_kconfig.pl line 33, <IN> line 4.
i am open to change the OS version even as this is just a test system,
any help will be really appreciated
Ali
akashif
Postby akashif » Wed Feb 29, 2012 11:02 pm
i tried that on CentOS5.7
[[email protected] linux-tbs-drivers_110818]# uname -r
2.6.18-274.18.1.el5PAE
Package kernel-devel-2.6.18-274.18.1.el5.i686 already installed and latest version
it seems like some issue with CentOS, as i tested 5.7 and 6.2, both have 100% same issue while making.
make -C /root/linux-tbs-drivers_110818/linux-tbs-drivers/v4l
make[1]: Entering directory `/root/linux-tbs-drivers_110818/linux-tbs-drivers/v4l'
No version yet, using 2.6.18-274.18.1.el5PAE
make[1]: Leaving directory `/root/linux-tbs-drivers_110818/linux-tbs-drivers/v4l'
Preparing to compile for kernel version 2.6.18
File not found: /lib/modules/2.6.18-274.18.1.el5PAE/build/.config at ./scripts/make_kconfig.pl line 32, <IN> line 4.
Ali
akashif
