Drivers won't make
Drivers won't make
Postby ginge6000 » Mon Jul 11, 2011 1:35 am
I keep getting errors when I do the make && make install with the latest drivers under Ubuntu server 11.04.
Code: Select all
make -C firmware
make[2]: Entering directory `/home/administrator/tbs/linux-tbs-drivers/v4l/firmware'
  CC  ihex2fw
make[2]: gcc: Command not found
make[2]: *** [ihex2fw] Error 127
make[2]: Leaving directory `/home/administrator/tbs/linux-tbs-drivers/v4l/firmware'
make[1]: *** [firmware] Error 2
make[1]: Leaving directory `/home/administrator/tbs/linux-tbs-drivers/v4l'
make: *** [all] Error 2
Anyone able to help?????
ginge6000
Re: Drivers won't make
Postby SergioDanielG » Mon Jul 11, 2011 8:11 am
ginge6000 wrote:Hi,
Code: Select all
make -C firmware
  CC  ihex2fw
You need gcc compiler. But maybe you need something more.
If you are using a debian like disto, do in a terminal:
#apt-get install module-assistant
With this you will install all that you need to compile everything.
SergioDanielG
Postby ginge6000 » Mon Jul 11, 2011 4:28 pm
Thank you! What an idiot! Installed GCC and it all worked fine. Now I just need to get mythtv setup.....
ginge6000
Postby SergioDanielG » Tue Jul 12, 2011 1:04 am
If you are using a Debian like disto, only
# apt-get install mythtv
then, stop mythtv-backend and run mythtv-setup
Configure it, exit from mythtv-setup and run mythfilldatabase
(from memory)
Tell me if you need more detailed information...
SergioDanielG
Postby smv1210 » Wed Jul 13, 2011 1:32 am
For Ubuntu, as a most popular "Debian like distro", it would be better to use:
# apt-get install mythbuntu-control-centre
Or... just use mythbuntu distro as it is :)
smv1210
Postby zebiden » Thu Mar 24, 2016 7:07 am
You have not compiler in system. You are using ubuntu? Try "apt-get install build-essential", and retry driver install.
zebiden
