Hi Steven,
I have problem with the tbs 6981, after resume my htpc from sleep i get no signal.i have try older divers but still the same problem.i also have test it in wmc and mediaportal,both programs give me the same problem.
Before some weeks i buy the tbs 8921 and also i had problems with BSOD after pc waking up from sleep,but with your fast support you have fix this problem with new drivers.
I will also appreciated you support for this card too.
Also i notice with the latest drivers 2.0.0.19 from 6981, tv zapping from hd to sd and via verse its getting to long but with drivers 2.0.0.18 its very fast.
Motherboard: GA-880GM-UD2H
Gpu: SAPPHIRE HD 5450 512MB DDR2 PCIE HDMI
4 GB memory
Waiting for your support.
Nikos
