problem in Windows 8 Consumer Preview(Solved)
Postby saeid72 » Tue Mar 06, 2012 5:06 pm
hello
I can not speak English!!
Please make drivers for Windows 8 Consumer Preview 64bit
Also driver windows 7 problem With sattlite hack . Of forced I first installed Tuner4PC and After getting the ping I wash uninstall Tuner4PC
Problem with openvpn The satellite hacking.When someone comes on the Mac Total rate MAC Is added to my send.To solve this problem privatefirewall 7 I use
Sorry for writing I use Google translate
thanks
saeid72
Re: problem in Windows 8 Consumer Preview
Postby SergioDanielG » Tue Mar 06, 2012 7:14 pm
Window 8 it's a public beta from... 1 week ago...
I wish TBS do it, but is not too early?
Best resgards.
SergioDanielG
Postby saeid72 » Wed Mar 07, 2012 12:48 am
It is too early But other problems were While there are beta There are more frames in games
saeid72
Postby steven » Wed Mar 07, 2012 8:29 am
Hi All
We just have tested in Windows 8 X86 version which is ok,We will have more test in x64 verison. :)
and when Windows 8 is official released ,we will release TBS Windows 8 driver as soon as possible too.
Postby satHD » Tue Jun 19, 2012 3:06 pm
I have my TBS5922 working fine on Window 8 Release Preview.
Though I did have to disable Windows 8 Driver Signature Enforcement to install the driver.
Disable Windows 8 Driver Signature Enforcement
Windows Key + R
Enter shutdown.exe /r /o /f /t 00
Click the "OK" button
System will restart to a "Choose an option" screen
Select "Troubleshoot" from "Choose an option" screen
Select "Advanced options" from "Troubleshoot" screen
Select "Windows Startup Settings" from "Advanced options" screen
Click "Restart" button
System will restart to "Advanced Boot Options" screen
Select "Disable Driver Signature Enforcement"
Once the system starts, install your drivers as you would on Windows 7
satHD
Postby steven » Tue Jun 26, 2012 11:21 am
Hi satHD
We have tested in Windows 8 Consumer Preview with Driver Signature Enforcement which is ok.
Would you min having a test with the latest x64 driver?
Postby satHD » Wed Jun 27, 2012 3:43 am
I'll give it a test tonight.
satHD
Postby satHD » Wed Jun 27, 2012 4:58 pm
10/10 Good work guys.
This was tested on build 8400 (Release Preview)
satHD
