Driver Problems Interface2 wont get a lock after a while
Postby nachtschatten » Sat Aug 28, 2010 7:57 pm
Hi have the TBS 6980 and a mythbuntu 10.04.01 LTS Box. Kernel :2.6.32-23-generic-pae #37-Ubuntu SMP
my dmesg show the following:
Aug 28 13:28:07 mythschatten kernel: [ 8.611454] cx23885 driver version 0.0.2 loaded
Aug 28 13:28:07 mythschatten kernel: [ 8.611498] cx23885 0000:03:00.0: PCI INT A -> Link[LN0A] -> GSI 19 (level, low) -> IRQ 19
Aug 28 13:28:07 mythschatten kernel: [ 8.611590] CORE cx23885[0]: subsystem: 6980:8888, board: TurboSight TBS 6980 [card=29,autodetected]
Aug 28 13:28:07 mythschatten kernel: [ 9.334233] cx23885_dvb_register() allocating 1 frontend(s)
Aug 28 13:28:07 mythschatten kernel: [ 9.334256] cx23885[0]: cx23885 based dvb card
Aug 28 13:28:07 mythschatten kernel: [ 9.428487] DVB: registering new adapter (cx23885[0])
Aug 28 13:28:07 mythschatten kernel: [ 9.431720] cx23885_dvb_register() allocating 1 frontend(s)
Aug 28 13:28:07 mythschatten kernel: [ 9.431723] cx23885[0]: cx23885 based dvb card
Aug 28 13:28:07 mythschatten kernel: [ 9.463112] DVB: registering new adapter (cx23885[0])
Aug 28 13:28:07 mythschatten kernel: [ 9.466215] cx23885_dev_checkrevision() Hardware revision = 0xb0
Aug 28 13:28:07 mythschatten kernel: [ 9.466221] cx23885[0]/0: found at 0000:03:00.0, rev: 2, irq: 19, latency: 0, mmio: 0xfd600000
Aug 28 13:28:07 mythschatten kernel: [ 9.466228] cx23885 0000:03:00.0: setting latency timer to 64
Aug 28 13:28:07 mythschatten kernel: [ 9.466233] IRQ 19/cx23885[0]: IRQF_DISABLED is not guaranteed on shared IRQs
Mythbackend.log:
2010-08-28 13:47:06.881 TVRec(8): Changing from None to WatchingLiveTV
2010-08-28 13:47:06.890 TVRec(8): HW Tuner: 8->8
2010-08-28 13:47:06.963 ProgramInfo(1051_20100828132956.mpg), Warning: MarkAsInUse(false, 'recorder'->'') -- use has changed since first setting as in use.
2010-08-28 13:47:06.970 ProgramInfo(1051_20100828132956.mpg), Warning: MarkAsInUse requires a key to delete in use mark
2010-08-28 13:47:07.003 AutoExpire: CalcParams(): Max required Free Space: 3.0 GB w/freq: 14 min
2010-08-28 13:47:07.013 ProgramInfo(): Updated pathname '':'' -> '1051_20100828134706.mpg'
2010-08-28 13:47:07.061 ProgramInfo(): Updated pathname '':'' -> '13020_20100828134658.mpg'
2010-08-28 13:47:07.071 ProgramInfo(): Updated pathname '':'' -> '1051_20100828134706.mpg'
Mythfrondend.log:
2010-08-28 13:52:34.892 ProgramInfo(): Updated pathname '':'' -> '1051_20100828135234.mpg'
2010-08-28 13:52:34.898 LiveTVChain(live-schattentubebuntu-2010-08-28T13:52:21): SwitchTo() not switching to current
2010-08-28 13:52:34.904 OpenGLVideoSync()
2010-08-28 13:52:34.948 Video timing method: SGI OpenGL
2010-08-28 13:52:35.041 VDPAU: Added 2 output surfaces (total 4, max 4)
2010-08-28 13:52:53.168 TV: Attempting to change from WatchingLiveTV to None
2010-08-28 13:52:53.213 ~OpenGLVideoSync() -- closing opengl vsync
2010-08-28 13:52:53.218 TV: Changing from WatchingLiveTV to None
The problem: this is the interface 2 on the tbs 6980 is not able to get a lock after using it 2-3 month. If i go to the mythfrondend and switch to imput 2 the interface shows "no lock". Interface 1 is working without trouble ... interface 2 was working since one bad day ..
what can i do ?
nachtschatten
