suggested cpu/motherboard/video for my TBS8922
Postby smbs » Thu Apr 26, 2012 2:15 pm
I bought the above card a few months ago but due to my old computer performance I am unable to watch HD
I would like to upgrade all required components.Any suggestions or links on required hardware for theTBS8922 to work well would be appreciated. Pls note I am looking to keep required budget as low as possible--no really highend components which I understand would work fine!
Many thanx
Steven
smbs
Re: suggested cpu/motherboard/video for my TBS8922
Postby smile » Thu Apr 26, 2012 3:59 pm
HI smbs
http://www.tbsdtv.com/products/tbs8922-dvb-s2-tv-tuner-pci-card.html This is our product TBS8922 description, and it has the hardware configuration requirements for play DVBS2 HDTV.
Thanks !
smile
Postby smbs » Thu Apr 26, 2012 5:13 pm
For DVB-S2 HDTV:
Dualcore CPU
1GB RAM or Above
The above is very general and not much help!!
I would like information which is much more specific based on a working/existing configuration!!
Regards and thanx
smbs
Postby smile » Fri Apr 27, 2012 9:40 am
Hi smbs
what about the specific need of the lowest configuration.we also has not tested.I can offer my computer's configuration for your reference.
OS : win 7(32 bit)
CPU: AMD Athlon(tm) II X2 250 Processor(3000 Mhz)
computer's mainboard: gigabyte GA-880G-USB3
RAM : 2.00 GB ( PC3-10600 DDR3 SDRAM 1333MHz)
graphics card : ATI Radeon HD 4250 (256MB)
Thanks !!!
smile
Postby smbs » Sun Apr 29, 2012 4:39 pm
Thanx for your reply
Does the 8922 run on your computer without hitches including Hd channels.
If so thats a good starting point to build on
Steven
smbs
Postby steven » Tue May 01, 2012 9:28 am
Hi smbs
My computer is use I3 process quad core. and Graph card with 512 MB memery, RAM is 4G DDR1333MHz.
Which is very good with HD channel. :D
