Merge DVB Drivers ...
Postby Kompik » Sat Apr 28, 2012 7:20 pm
I have two DVB card in one system.
1. SkyStar HD2 + CI
2. TBS 6928
Stock and your (TBS) driver support SkyStar, but didn`t support CI module connected to SkyStar.
I have Driver pack from Igor Leplianinov ( http://mercurial.intuxication.org/hg/s2-liplianin ).
This driver fully support SkyStar HD2 + CI, but don`t support TBS DVB cards :(
I want to use both dvb card in same time ...
How i can merge you driver and driver from Leplianinov ?
May be i can compile require modules and load it by request ?
P.S. Sorry for my English.
Kompik
Re: Merge DVB Drivers ...
Postby SergioDanielG » Mon Apr 30, 2012 7:21 pm
Hi Kompik. Do you know wich driver is using SkyStar card? Maybe you can try to separete files and compile it separatelly.
Best regards
SergioDanielG
Postby Kompik » Wed May 02, 2012 2:48 pm
I`m attached lsmod output.
SkyStarHD2_CI_Liplianinov.modules - Installed Liplianinov drivers. SkyStar is Work, TBS card not detected.
TBS_TBS_Drivers_original.modules - All DVB card recognized, but CI slot (/dev/dvb/adapter?/ca) not available.
I think SkyStar HD2 use some modules:
mantis 29493 0
lnbp21 1364 1 mantis
mb86a16 15162 1 mantis
ir_core 9091 9 rc_vp1041,ir_sony_decoder,ir_jvc_decoder,ir_rc6_decoder,ir_rc5_decoder,mantis,ir_nec_decoder
stb6100 5262 1 mantis
tda10021 3970 1 mantis
tda10023 5171 1 mantis
stb0899 27248 1 mantis
stv0299 6600 1 mantis
dvb_core 62970 2 mantis,stv0299
i2c_core 12787 13 mantis,lnbp21,mb86a16,stb6100,nouveau,drm_kms_helper,tda10021,drm,tda10023,stb0899,stv0299,i2c_algo_bit,i2c_i801
DVB_Modules.zip
lsmod output for both variants of installed drivers.
(4.19 KiB) Downloaded 124 times
Kompik
Postby SergioDanielG » Wed May 02, 2012 10:19 pm
Maybe it's not a good idea, a developer can say it better, but... What's happend if you copy source file from Leplianinov driver (only files used by SkyStar) to tbs driver source.
It's like, driver's file needed by one are diferent of other. Aditionally, you can see #include section in sources and be sure to copy all necesary files.
I repeat, maybe it's not a good idea...
Best regards.
SergioDanielG
Postby Kompik » Thu May 03, 2012 1:52 pm
If i copy mantis* source, i have a lot of error when compile code.
Kompik
Postby Kompik » Thu May 03, 2012 10:33 pm
Can you write with driver (modules) is using TBS6928/6280/6984 cards ?
I will try load compiled modules by modprobe on system with installed drivers from liplianinov...
Kompik
Postby SergioDanielG » Fri May 04, 2012 8:23 am
Bad idea from me... There was a lot of changes between tbs and liplianin drivers. :?
SergioDanielG
Postby Kompik » Fri May 04, 2012 3:36 pm
Anyway, can i load your compiled drivers on my system with drivers from Liplianin?
Kompik
Postby Kompik » Thu May 10, 2012 8:30 pm
Another question...
What i need to define in "make menuconfig" to compile driver fow your cards ?
Kompik
