driver 1.0.1.3 problem
Postby lukjod » Sat May 26, 2012 5:06 pm
After updating driver to 1.0.1.3 card stop to work and gives info not signal detected. I've checked it in Media Portal and Prog DVB both in newest versions. It showed quality of signal 0 in both of them and can't find any program in scan mode. After revert back to 1.0.1.2 all is working fine.
lukjod
Re: driver 1.0.1.3 problem
Postby steven » Tue May 29, 2012 10:13 am
Hi lukjod
Would you mind telling us which satellite and which Transponder you are using.
and what's you LNB type and setting?
Do you have used DiSeqc?
Just give us more information as you can,so we can take a test with your setting.
Postby lukjod » Tue May 29, 2012 2:16 pm
Hi Steven
I'm using very simple setup with 1 lnb on Hot Bird provider Polish Cyfra without DiSeqc. Im also using Aston Crypt cam 2.26 version
I hope that will help You unbug it
rgds
Lukasz
lukjod
Postby steven » Tue May 29, 2012 5:10 pm
Hi lukjod
Would you mind using this version DVBDream to have a test:
https://hotfile.com/dl/157132084/a65cbac/dvbdream_setup_v17c_oem_3.zip.html
after download it please use this linker to delete it :
https://hotfile.com/kill/157132084/252c81b50cde42e640743c8722b13277071d0c55.html
Because we just use this version DD to had a test,all is ok.
Postby herrbasan » Wed May 30, 2012 6:50 pm
I can't tell you exactly what's wrong, but with 1.0.1.3 the support for MediaPortal is skrewed up too. Scanning for channels resulted in lot's of "No Signal" messages on more then half of the transponders. I reverted back to 1.0.1.2.
TBS 6828 + Unicam Deltacrypt (Sparta 5.33)
MediaPortal 1.2.2 Final
Windows 7 x64
TBS 6928 / Unicam Deltracrypt CAM / Sky Germany V13 Card
Windows 7 x64 / MediaPortal 1.2.3
herrbasan
Postby lukjod » Thu May 31, 2012 1:28 am
Hi Steven
today I have tried DVBDream and all is working fine, but only on that soft You gave me link for. The rest including MediaPortal (my HTPC solution) works fine only on 1.0.1.2 driver on newest driver it gives no signal info
lukjod
Postby steven » Thu May 31, 2012 9:36 am
Hi lukjod&herrbasan
Would you mind using this new driver to have a test with MediaPortal.
V1.0.1.4:
https://hotfile.com/dl/157286452/5c6d85d/TBS6928_20120531-release.zip.html
And send your test report here. :)
Postby herrbasan » Thu May 31, 2012 10:34 am
I've tested the new version, and did a full channel scan. Where i had problems before ("No Signal" on many transponders) the new driver succeeded. I also tested the general functionality and the new driver worked quite well. I'll keep it and will report if i can find any errors. But so far, i'd would give it a "go" :)
Tested on:
Windows 7 x64
MediaPortal 1.2.3
Unicam Deltacrypt (Sparta 5.33) with V13 Sky Germany Card
herrbasan
Postby lukjod » Thu May 31, 2012 6:45 pm
Yes, all is ok, Media Portal works as espected. New version works very good
Thank You
Media Portal 1.2.2
Windows 7 32 bit
lukjod
Postby herrbasan » Thu May 31, 2012 10:16 pm
I'm very pleased with the support here. Added to the fact that the TBS 6928 is by far the best DVB hardware with CI Support out there, a quick an responsive support makes it a no-brain-er to recommend.
Good Job TBS :)
herrbasan
