Big Problem with S2 8psk All Hd CHannel have freez
Postby clubrotation » Fri Jul 13, 2012 8:53 am
im have problem help me
see this pic
all driver and codec test not fix
clubrotation
Re: Big Problem with S2 8psk All Hd CHannel have freez
Postby clubrotation » Fri Jul 13, 2012 8:55 am
my 6925all freq have good resive 16 and 32 easy resive but all hd chandel have frezz
all hd chandel test im my pc with dvb prof is good
clubrotation
Postby clubrotation » Sat Jul 14, 2012 3:00 am
not any body in here help me??????????????????????????????????????
clubrotation
Postby Johannes2009 » Mon Jul 16, 2012 12:43 am
Sometimes I saw it trying different dvb programs. I think the sensitivity of the card is better exploited in a soft than another, but generally depends on the configuration of the PC.
Johannes2009
Postby clubrotation » Mon Jul 16, 2012 5:54 am
im test with other pc but not fix problem im test with all palyer dvb prog dvb tbs palayer my theatre dvb viewer and all codec test
im record video from dvb look this video plz help me
http://www.mediafire.com/?1uy5d2kt1sad171
clubrotation
Postby SergioDanielG » Tue Jul 17, 2012 5:14 am
When you use TBS6925, CPU use it's 60%. With Prof 8000, CPU use it's 55%. What about RAM memory?
Additionally, wich CAM module are you using? Or channels it's not really encrypted?
Best regadrs
SergioDanielG
Postby marec » Tue Jul 17, 2012 5:41 am
Did you know if this isnt a "continuous mode" signal of DVB-S2 standards?
Check it with crazyscan in the constelation monitor panel.
To be decoded, a signal should be "transport stream" mode.
marec
Postby clubrotation » Tue Jul 17, 2012 5:42 am
ram=3gig
use hadu and cccam
test on no encrypted channel on the eurobird 11881 ver 27500 have free hd cahnel fashion one hd
but freez
Do not know what
clubrotation
Postby clubrotation » Tue Jul 17, 2012 5:45 am
im test with crazy scan for example bbc hd have 10db in tbs6925 test with other dvb prof 8000 have 10 db
but all hd chanel in s2 8psk have problem
s1 and qpsk and 16 32 apsk not problem
only s2 8psk have problem
clubrotation
Postby marec » Tue Jul 17, 2012 6:19 am
But, please check the stream mode. Look if it is not MIS input too.
marec
Users browsing this forum: Google [Bot] and 0 guests
