6925 with TSREADER??
Postby wejones » Mon Jul 25, 2011 4:50 am
I downloaded the TSREADER source dll file from the web page. When I put it in TSREADER, TSREADER recognizes the card, however it doesn't seem to work. It doesn't come up with the normal advanced tuner menus allowing you to specify DVB-S2, or the other advanced modes. Also, even if I try to lock a regular DVB-S transponder, nothing seems to happen.
The advertising says that it works with TSREADER, and the source file came from the TBS web page, so it seems like it should work, but it doesn't.
I can get to TSREADER through CrazyScan, which is nice when searching for signals, but I'd really like to do it directly also, since TSREADER is what I use for 95% of my viewing. Any ideas?
wejones
Re: 6925 with TSREADER??
Postby starman345 » Mon Jul 25, 2011 5:52 am
I"m finding the same situation with my TBS 6925 card. The card is recognized, it acts like its tuning a signal, but nothing shows up in the analyzer window...no data. It would be nice to be able to use this great card directly with TSREADER for analyzing all the different signals it finds.
10' dish- Bullseye II c/ku
55.5W to 139W
Windows 8.1 64 bit
TBS 8922 Prof 7301 TBS 6925
starman345
Postby Magwitch » Mon Jul 25, 2011 8:31 pm
Same for me. TSReader recognises the card in the bottom corner, but says 'no signal'.
Magwitch
Postby DVB » Tue Jul 26, 2011 5:07 am
Hmmm...
I see data after tuning for TP with BDASuorce_TBS6925.dll (W7 x64)
You mean that You've got completely no data in window? No Active PID's, Video Decode etc.?
DVB
Postby starman345 » Tue Jul 26, 2011 5:34 am
DVB wrote:Hmmm...
Thats right, I see signal but no data, empty panes. I take it you are using windows 7. Windows XP 32 bit here, maybe that is a clue
55.5W to 139W
Windows 8.1 64 bit
starman345
Postby steven » Tue Jul 26, 2011 9:44 am
Hi starman345
i have updated the tbs6925's tsreader
http://hotfile.com/dl/125017901/2f712c1 ... 5.rar.html
please try this.
thanks
Postby steven » Tue Jul 26, 2011 9:48 am
starman345 wrote:
DVB wrote:Hmmm...
Hi starman
about the DSS,would you mind give me more information.
The driver scan mode is auto scan.
thanks
Postby starman345 » Tue Jul 26, 2011 5:44 pm
steven wrote:Hi starman345
please try this.
thanks
Hi Steven, thanks for the new source but the situation is the same for me, TSREADER shows no information at all. I sent PM about the DSS information
55.5W to 139W
Windows 8.1 64 bit
starman345
Postby sotos65 » Tue Jul 26, 2011 8:15 pm
In windows 7 64bit it works fine,
sotos65
Postby Alx » Tue Jul 26, 2011 9:48 pm
I was able to lock successfully DVB-S/-S2 transponders on my TSReader 2.8.47, based on WinXP x32 environment,
driver v1.0.1.4, TSReader source module v1.0.7.0. I confirm, I could not find any advanced tuner menus allowing
to specify DVB-S2, or the other advanced modes (16/32APSK, ACM, StreamID...), anyway for DVB-S/-S2 TP's with
standard QPSK/8PSK I did not experience any problems...
Some pics are attached (I tested TP at Astra 1G at 31.5°E).
Is it possible to add some advanced functionality DVB-S2 mode parameters to TSReader TBS6925 Source Module Menu
(at least, for normal DVB Transport Stream transmissions) ??
Alx
