DVB-C doesn't return correctly from standby mode
Postby fufnf » Sun Sep 05, 2010 12:45 pm
I have USB DVB-C TV Stick tuner and it has a problem with returning from windows stand by mode.
[english: This device is not working properly, because Windows can not load the correct driver for it. (Code 31)]
To reproduce error, the tuner must be in use (for example, running ProgDVD) when you're moving PC into stand by mode.
To fix problem I disable device in Device Manager and then enable it again.
My software configuration:
Windows 7 X64 Professional
USB DVB-C TV Stick driver ver. 1.0.2.1
fufnf
Re: DVB-C doesn't return correctly from standby mode
Postby fufnf » Fri Jun 24, 2011 12:56 pm
Thank you for your answer!
fufnf
Postby steven » Fri Jun 24, 2011 2:57 pm
fufnf wrote:Thank you for your answer!
Hi sorry for the problem,we will check it later
Postby fufnf » Sun Jan 01, 2012 9:58 am
Hello. Thank you for your answer. Can you tell in how many years will you check it? Will it be in this century?
fufnf
