TBS6280 incompatible with ASRock Z77E-ITX
Postby Sotamarsu » Tue Sep 11, 2012 5:04 pm
I just got ASRock Z77E-ITX motherboard to my test bench and got it working nicely except one thing. The machine won't detect TBS6280 TV Tuner Card. The device won't come to Windows 7 device manager. I have updated BIOS to 1.30 and tried it with different settings, but it's still not working.
This problem is the PCI-E 1.0a compatible problem and someone at TBS should contact Asus and ASRock immediately.
TV Tuner Card is working with Dell Optiplex GX620 and ASUS P8Z77-V Deluxe. It isn't working with ASUS E45M1-I Deluxe (BIOS 0306) and now ASRock Z77E-ITX (BIOS 1.10 and 1.30).
EDIT: I can confirm that TBS6280 is working with Asus Maximus V Gene (in PCI-E x16 and x4) and ASRock Z77 Extreme4 (in PCI-E x1)
Sotamarsu
Re: TBS6280 incompatible with ASRock Z77E-ITX
Postby steven » Wed Sep 12, 2012 2:36 pm
Hi Sotamarsu
We will contact Asus and ASRock as soon as possible about this.
And you can send your detail problem to Asus and ASRock too,if they received
a lot of feedback about this,maybe they can solve this more quickly.
Postby Sotamarsu » Thu Sep 13, 2012 9:57 pm
I can confirm that Asus P8Z77-I Deluxe is compatible with TBS6280.
Sotamarsu
Postby steven » Sat Sep 15, 2012 11:56 am
Hi Sotamarsu
Thanks for your share.
and we have got the news that Intel has updated the BIOS to support PCI-E 1.0a.
So maybe next time other mainboard will update the BIOS too. :)
Postby piccio » Sat Feb 02, 2013 11:46 pm
I've asrock h77m-itx (with the latest bios version 1.30) and tbs6280 and I've the same problem.
I've contacted asrock support and 1 day later they have send to me a new bios (1.40a).
It appears to be working.
piccio
Postby stillcrazy » Wed Feb 06, 2013 11:05 pm
Hi Piccio
I have not found the 1.40a BIOS on Asrock website.
You can confirm to me that this resolves the problem with TBS6280
Is it possible for you to post a link to this new bios for us to download it.
Thank you
Best regards
stillcrazy
Postby piccio » Thu Feb 07, 2013 7:40 pm
stillcrazy wrote:Hi Piccio
Asrock has sent me the bios attached to his response to my email.
stillcrazy wrote:You can confirm to me that this resolves the problem with TBS6280
yes
stillcrazy wrote:Is it possible for you to post a link to this new bios for us to download it.
the file is more than 1MB and the forum doesn't permit its uploading.
I'll send it to you in pm.
If anyone want the bios send me a pm.
piccio
Postby mediavue » Sun Feb 10, 2013 6:23 pm
Hi.
I have two Z68M-ITX/HT by ASRock motherboards and cannot get the 6280 to work in either of them. They both have the latest Bios update of 2.40. I have tried two new 6280's in both boards and with both windows 7 and windows 8 - they don't even show up in device manager.
I have a Blackgold tuner which is also PCI-e and that does work fine in the slot. So that means that this board has an issue with this card.
Can someone please post me a bios update for my board that supports this? ASRock are closed for the new year for two weeks!
Thanks.
mediavue
