win7 blue screen
win7 blue screen
Postby mikeh » Mon Oct 01, 2012 6:23 am
After having the first defective TSB6984 replaced I am getting blue screen restarts.
I have had the card replaced. Now I have had 2 blue screens seemingly caused by the TBS6984.
Please advise what other information I can give you.
Mike Harris
* Bugcheck Analysis *
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000000000000fc, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88003e3faab, address which referenced memory
Debugging Details:
READ_ADDRESS: 00000000000000fc Nonpaged pool
CURRENT_IRQL: 2
FAULTING_IP:
TBS6984_64+36aab
fffff880`03e3faab 83b9fc00000000 cmp dword ptr [rcx+0FCh],0
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: TvService.exe
TRAP_FRAME: fffff88006fbd3c0 -- (.trap 0xfffff88006fbd3c0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000001000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88003e3faab rsp=fffff88006fbd550 rbp=0000000000000000
r8=0000000000000000 r9=0000000000000000 r10=0000000000000000
r11=0000000000000048 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe nc
TBS6984_64+0x36aab:
fffff880`03e3faab 83b9fc00000000 cmp dword ptr [rcx+0FCh],0 ds:00000000`000000fc=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002ccfbe9 to fffff80002cd0640
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
TBS6984_64+36aab
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: TBS6984_64+36aab
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: TBS6984_64
IMAGE_NAME: TBS6984_64.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4f6a8ff3
FAILURE_BUCKET_ID: X64_0xD1_TBS6984_64+36aab
Followup: MachineOwner
mikeh
