Ubuntu 12.10 kernel 3.6.6 - Compiled error
Postby bl4ck » Sat Nov 17, 2012 3:43 am
Hello
I have problem with compiled driver tbs-linux-drivers_v121105 in Ubuntu 12.10. Please help.
Linux HTPC 3.6.6-030606-generic #201211050512 SMP Mon Nov 5 10:20:03 UTC 2012 i686 i686 i686 GNU/Linux
03:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 03)
        Subsystem: Device [6922:0001]
        Interrupt: pin A routed to IRQ 10
        Region 0: Memory at fb300000 (64-bit, non-prefetchable) [size=1M]
/usr/local/src/6922/linux-tbs-drivers/v4l/tda18218.c: In function 'tda18218_attach':
/usr/local/src/6922/linux-tbs-drivers/v4l/tda18218.c:302:2: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized]
  CC [M]  /usr/local/src/6922/linux-tbs-drivers/v4l/tda18212.o
/usr/local/src/6922/linux-tbs-drivers/v4l/tda18212.c: In function 'tda18212_attach':
/usr/local/src/6922/linux-tbs-drivers/v4l/tda18212.c:248:2: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized]
  LD [M]  /usr/local/src/6922/linux-tbs-drivers/v4l/saa7146.o
  LD [M]  /usr/local/src/6922/linux-tbs-drivers/v4l/saa7146_vv.o
  LD [M]  /usr/local/src/6922/linux-tbs-drivers/v4l/saa716x_core.o
  LD [M]  /usr/local/src/6922/linux-tbs-drivers/v4l/saa716x_tbs-dvb.o
  CC [M]  /usr/local/src/6922/linux-tbs-drivers/v4l/rc-adstech-dvb-t-pci.o
ld: Relocatable linking with relocations from format elf64-x86-64 (/usr/local/src/6922/linux-tbs-drivers/v4l/tbsctrl.o) to format elf32-i386 (/usr/local/src/6922/linux-tbs-drivers/v4l/saa716x_tbs-dvb.o) is not supported
make[3]: *** [/usr/local/src/6922/linux-tbs-drivers/v4l/saa716x_tbs-dvb.o] Błąd 1
make[3]: *** Oczekiwanie na niezakończone zadania....
make[2]: *** [_module_/usr/local/src/6922/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-headers-3.5.0-18-generic'
make[1]: *** [default] Błąd 2
make[1]: Opuszczenie katalogu `/usr/local/src/6922/linux-tbs-drivers/v4l'
make: *** [all] Błąd 2
xbmc@HTPC:/usr/local/src/6922/linux-tbs-drivers$
bl4ck
Re: Ubuntu 12.10 kernel 3.6.6 - Compiled error
Postby SergioDanielG » Sat Nov 17, 2012 10:52 am
Hi bl4ck.
Check your installation steps.
You are using 64 bits driver in 32 bits kernel.
Try again, remember run the correct script to select 32 bits drivers.
Best regards.
SergioDanielG
Postby bl4ck » Sat Nov 17, 2012 5:43 pm
README
- for x86 kernel 3.x (x86 32 bit installations of kernel 3.x):
# ./v4l/tbs-x86_r3.sh
Facepalm :) I'm sorry.
I had a rough day. Thank you for help.
Best regards
bl4ck
