Installing 6984 in Fedora 18
Postby pff » Tue Feb 12, 2013 2:45 am
I followed the README_TBS6981 for installing a TBS6984 because it seemed the closest one, after restart the card did not show up in dmesg.
Code: Select all
[[email protected] atbs]# ls
astra_scan-s2.conf  linux-tbs-drivers.tar.bz2  v4l-cx23885-avcore-01.fw
astra_szap-s2.conf  scan-s2.tar.bz2
linux-tbs-drivers   szap-s2.tar.bz2
[[email protected] atbs]# cd linux-tbs-drivers/
[[email protected] linux-tbs-drivers]# uname -a
Linux luigi.sharpyweb 3.7.6-201.fc18.x86_64 #1 SMP Mon Feb 4 15:54:08 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
[[email protected] linux-tbs-drivers]# ./v4l/tbs-x86_64.sh
[[email protected] linux-tbs-drivers]# make && make install
make -C /home/pff/Downloads/tbs-linux-drivers_v130127/atbs/linux-tbs-drivers/v4l
make[1]: Entering directory `/home/pff/Downloads/tbs-linux-drivers_v130127/atbs/linux-tbs-drivers/v4l'
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/home/pff/Downloads/tbs-linux-drivers_v130127/atbs/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/home/pff/Downloads/tbs-linux-drivers_v130127/atbs/linux-tbs-drivers/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for `default'.
Kernel build directory is /lib/modules/3.7.6-201.fc18.x86_64/build
make -C /lib/modules/3.7.6-201.fc18.x86_64/build SUBDIRS=/home/pff/Downloads/tbs-linux-drivers_v130127/atbs/linux-tbs-drivers/v4l  modules
make[2]: Entering directory `/usr/src/kernels/3.7.6-201.fc18.x86_64'
  Building modules, stage 2.
  MODPOST 1 modules
make[2]: Leaving directory `/usr/src/kernels/3.7.6-201.fc18.x86_64'
./scripts/rmmod.pl check
found 1 modules
make[1]: Leaving directory `/home/pff/Downloads/tbs-linux-drivers_v130127/atbs/linux-tbs-drivers/v4l'
make -C /home/pff/Downloads/tbs-linux-drivers_v130127/atbs/linux-tbs-drivers/v4l install
\nRemoving obsolete files from /lib/modules/3.7.6-201.fc18.x86_64/kernel/drivers/media/IR/keymaps:
\nRemoving obsolete files from /lib/modules/3.7.6-201.fc18.x86_64/kernel/drivers/media/video:
\nRemoving obsolete files from /lib/modules/3.7.6-201.fc18.x86_64/kernel/drivers/media/dvb/cinergyT2:
\nRemoving obsolete files from /lib/modules/3.7.6-201.fc18.x86_64/kernel/drivers/media/common:
\nRemoving obsolete files from /lib/modules/3.7.6-201.fc18.x86_64/kernel/drivers/media/dvb/frontends:
\nRemoving obsolete files from /lib/modules/3.7.6-201.fc18.x86_64/kernel/drivers/media/IR:
Installing kernel modules under /lib/modules/3.7.6-201.fc18.x86_64/kernel/drivers/media/:
/sbin/depmod -a 3.7.6-201.fc18.x86_64
make -C firmware install
Installing firmwares at /lib/firmware: vicam/firmware.fw dabusb/firmware.fw dabusb/bitstream.bin ttusb-budget/dspbootcode.bin cpia2/stv0672_vp4.bin av7110/bootcode.bin
Code: Select all
after restarting:
[[email protected] linux-tbs-drivers]# dmesg | grep frontend
[[email protected] linux-tbs-drivers]# dmesg | grep DVB
[[email protected] linux-tbs-drivers]# lspci -v
04:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 02)
   Subsystem: Device 6984:0013
   Flags: bus master, fast devsel, latency 0, IRQ 15
   Memory at ff700000 (64-bit, non-prefetchable) [size=1M]
   Capabilities: [50] Express Endpoint, MSI 00
   Capabilities: [100] Vendor Specific Information: ID=0000 Rev=0 Len=088 <?>
is there a step that i'm missing out?
i cant see any errors during the make but the drivers obviously are not being loaded
thanks
also i found in the FAQ a suggestion to rm -rf and redo make && make install.
I tried that with a make clean as well and it still does not show up
i have dmesg / lspci log files but i cannot find an extension thats allowed to be posted....
pff
Re: Installing 6984 in Fedora 18
Postby updatelee » Tue Feb 12, 2013 3:03 am
Do you have the right TBS card selected in make menuconfig?
show the entire dmesg, pastebin.com works well for posting large logs.
Postby pff » Tue Feb 12, 2013 3:10 am
when am i supposed to do a make menuconfig?
this is the readme i have that i followed
Code: Select all
NOTE: this document assumes that all prerequisite packages like kerner headers
and build tools are already installed in your Linux system.
Most of the steps require root access to and basic knowledge of Linux system.
Create directory, for example /root/tbs and copy the following file to it:
- linux-tbs-drivers.tar.bz2 (S2API Linix driver for TurboSight TBS 6981)
- szap-s2.tar.bz2 (szap tool compatible with new DVB-S2 aware S2 API for Linux)
- scan-s2.tar.bz2 (scan tool compatible with new DVB-S2 aware S2 API for Linux)
- astra_szap-s2.conf (example configuration file for szap-s2)
- astra_scan-s2.conf (example configuration file for scan-s2)
- v4l-cx23885-avcore-01.fw (CX23885 AV core firmware, optional)
I.1 extract linux-tbs-drivers.tar.bz2 archive:
# tar xjvf linux-tbs-drivers.tar.bz2
I.2 go to driver package directory:
I.3 depending on your kernel version and if the kernel is x86 or
x86_64 (check output of 'uname -a') do:
- for x86 kernel 3.x (x86 32 bit installations of kernel 3.x):
# ./v4l/tbs-x86_r3.sh
- for x86 kernel 2.6.x (x86 32 bit installations of kernel 2.6.x):
# ./v4l/tbs-x86.sh
- for any x86_64 kernel (x86 64 bit installations of Linux):
I.4 build and install the driver:
I.5 reboot in order to load the newly installed driver:
# shutdown -r now
pff
Postby pff » Tue Feb 12, 2013 3:37 am
pff
Postby pff » Tue Feb 12, 2013 8:14 am
ok, I was just doing
Code: Select all
make clean
between attempts. instead of an apparently necessary distclean.
the following worked if anyone is interested:
Code: Select all
make distclean
./v4l/tbs-x86_64.sh
make release
make menuconfig
make
make install
in the menuconfig i didn't bother doing anything, just exited and saved changes.
was i following the wrong readme file or something? the ones in the driver download dont seem to give very much away.
result:
Code: Select all
[[email protected] pff]# dmesg | grep dvb
[   12.912392] DVB: registering new adapter (SAA716x dvb adapter)
[   14.361733] DVB: registering new adapter (SAA716x dvb adapter)
[   14.413445] DVB: registering new adapter (SAA716x dvb adapter)
[   14.462360] DVB: registering new adapter (SAA716x dvb adapter)
[[email protected] pff]# dmesg | grep frontend
[   14.361474] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[   14.413235] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[   14.462067] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[   14.512147] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
thanks.
pff
Postby updatelee » Tue Feb 12, 2013 12:22 pm
So judging by your log its working now?
Postby cody » Tue Feb 12, 2013 8:00 pm
hmm, i don't see any mistake even in the first driver installation attempt - i mean you follow the READMEs by the letter and everything is properly done and that's why i have no idea why it failed, but reinstalling it second time seems to help - please, note that i doubt "make distclean" and "make release" made any difference - i believe just reinstalling it second time helped, but have no idea what caused the problem the first time.
Postby pff » Tue Feb 12, 2013 11:16 pm
Hi guys,
I'm not sure about the real problem the first time around, the very first time i tried to run a make i think i had some permissions problems with the unzipped files.
I did a make clean, changed the permissions and redid the make.
To get a successful install i had to do a make distclean to properly restart the process.
I'm not sure if it was the permissions error or missing out the make menuconfig that was the issue in the first place.
Anyway it became obvious after seeing the make run sucessfully that previous attempts were not actually building any modules at all.
make install was running but it wasn't copying any files because none had been made.
pff
