3.9 support?
3.9 support?
Postby Begall » Sat Apr 20, 2013 5:40 pm
Just put on 3.9 RC7 to try and solve some other issues on my system, and while the drivers will successfully compile and install, they fail to load on restart with the following message:
[ 3.231105] tbs6982fe: module license 'TurboSight Proprietary: www.tbsdtv.com' taints kernel.
[ 3.231109] Disabling lock debugging due to kernel taint
[ 3.231126] tbs6982fe: module verification failed: signature and/or required key missing - tainting kernel
[ 3.233056] mei 0000:00:16.0: setting latency timer to 64
[ 3.233113] mei 0000:00:16.0: irq 48 for MSI/MSI-X
[ 3.251083] [drm] Initialized drm 1.1.0 20060810
[ 3.251346] saa716x_core: disagrees about version of symbol dvb_dmxdev_init
[ 3.251351] saa716x_core: Unknown symbol dvb_dmxdev_init (err -22)
[ 3.251380] saa716x_core: disagrees about version of symbol dvb_register_adapter
[ 3.251383] saa716x_core: Unknown symbol dvb_register_adapter (err -22)
[ 3.251402] saa716x_core: disagrees about version of symbol dvb_net_init
[ 3.251404] saa716x_core: Unknown symbol dvb_net_init (err -22)
[ 3.251418] saa716x_core: disagrees about version of symbol dvb_dmxdev_release
[ 3.251421] saa716x_core: Unknown symbol dvb_dmxdev_release (err -22)
[ 3.251428] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[ 3.251431] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[ 3.251434] saa716x_core: disagrees about version of symbol dvb_net_release
[ 3.251436] saa716x_core: Unknown symbol dvb_net_release (err -22)
[ 3.251442] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[ 3.251445] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[ 3.252391] saa716x_core: disagrees about version of symbol dvb_register_frontend
[ 3.252395] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
[ 3.252403] saa716x_core: disagrees about version of symbol dvb_unregister_adapter
[ 3.252405] saa716x_core: Unknown symbol dvb_unregister_adapter (err -22)
Begall
Re: 3.9 support?
Postby steven » Sat Apr 20, 2013 9:12 pm
Hi Begall
Can you send your detail information to our linux euro_support#tbsdtv.com,
we will answer you as soon as possible.
kind Regards
Re: 3.9 support?
Postby frednet » Sun May 12, 2013 7:24 am
just upgraded to Ubuntu 13.04 and I'm getting the same saa716x_core errors, was working ok on 12.10 previously. Not sure if this dmesg errror is relevant or unrelated
Code: Select all
[  111.965722] ------------[ cut here ]------------
[  111.965732] WARNING: at /build/buildd/linux-3.8.0/net/sched/sch_generic.c:254 dev_watchdog+0x242/0x250()
[  111.965734] Hardware name: System Product Name
[  111.965735] NETDEV WATCHDOG: eth1 (r8169): transmit queue 0 timed out
[  111.965736] Modules linked in: xt_LOG(F) xt_conntrack(F) iptable_filter(F) ipt_MASQUERADE(F) nf_nat_ftp(F) iptable_nat(F) nf_conntrack_ipv4(F) nf_defrag_ipv4(F) nf_nat_ipv4(F) nf_nat(F) nf_conntrack_irc(F) nf_conntrack_ftp(F) nf_conntrack(F) ip_tables(F) x_tables(F) 8021q(F) garp(F) dm_crypt(F) rfcomm bnep bluetooth nfsd(F) auth_rpcgss(F) nfs_acl(F) nfs(F) lockd(F) sunrpc(F) fscache(F) joydev(F) ir_lirc_codec(OF) lirc_dev(OF) ir_mce_kbd_decoder(OF) snd_hda_codec_hdmi ir_sony_decoder(OF) snd_hda_codec_realtek kvm ir_jvc_decoder(OF) ir_rc6_decoder(OF) arc4(F) ir_rc5_decoder(OF) bridge(F) stp(F) llc(F) tbs6922fe(POF) tbs6928fe(POF) snd_hda_intel stv090x(OF) ppdev(F) ir_nec_decoder(OF) snd_hda_codec ath9k snd_hwdep(F) dvb_core rc_core(OF) snd_pcm(F) ath9k_common edac_core microcode(F) k10temp sp5100_tco ath9k_hw psmouse(F) snd_page_alloc(F) edac_mce_amd parport_pc(F) serio_raw(F) i2c_piix4 asus_atk0110 i2c_algo_bit ath snd_seq_midi(F) snd_seq_midi_event(F) snd_rawmidi(F) snd_seq(F) mac80211 snd_seq_device(F) snd_timer(F) snd(F) cfg80211 fglrx(POF) amd_iommu_v2 soundcore(F) mac_hid shpchp lp(F) parport(F) vesafb(F) hid_generic usbhid hid wmi firewire_ohci pata_via firewire_core crc_itu_t(F) pata_acpi r8169 pata_atiixp ahci(F) libahci(F)
[  111.965785] Pid: 0, comm: swapper/1 Tainted: PF          O 3.8.0-20-generic #31-Ubuntu
[  111.965786] Call Trace:
[  111.965787]  <IRQ>  [<ffffffff810587ef>] warn_slowpath_common+0x7f/0xc0
[  111.965793]  [<ffffffff810588ec>] warn_slowpath_fmt+0x4c/0x50
[  111.965798]  [<ffffffff815e7332>] dev_watchdog+0x242/0x250
[  111.965801]  [<ffffffff815e70f0>] ? dev_graft_qdisc+0x90/0x90
[  111.965803]  [<ffffffff81068116>] call_timer_fn+0x36/0x110
[  111.965805]  [<ffffffff815e70f0>] ? dev_graft_qdisc+0x90/0x90
[  111.965807]  [<ffffffff81069d46>] run_timer_softirq+0x1f6/0x2a0
[  111.965810]  [<ffffffff81060f0f>] __do_softirq+0xcf/0x200
[  111.965812]  [<ffffffff816d4f1c>] call_softirq+0x1c/0x30
[  111.965815]  [<ffffffff81016555>] do_softirq+0x75/0xb0
[  111.965817]  [<ffffffff810611a5>] irq_exit+0xa5/0xb0
[  111.965819]  [<ffffffff816d57b3>] do_IRQ+0x63/0xe0
[  111.965821]  [<ffffffff816cb7ad>] common_interrupt+0x6d/0x6d
[  111.965822]  <EOI>  [<ffffffff81043fa6>] ? native_safe_halt+0x6/0x10
[  111.965828]  [<ffffffff810b1d9c>] ? clockevents_notify+0x4c/0x1a0
[  111.965830]  [<ffffffff8101c93f>] default_idle+0x4f/0x1a0
[  111.965832]  [<ffffffff8101cb22>] amd_e400_idle+0x92/0x120
[  111.965834]  [<ffffffff8101d5fe>] cpu_idle+0xfe/0x120
[  111.965836]  [<ffffffff816b50ce>] start_secondary+0x1e0/0x1e5
frednet
Re: 3.9 support?
Postby updatelee » Sun May 12, 2013 11:34 am
You probably still have some old some new media ko installed
try
sudo make rmmod
sudo make rminstall
sudo make install
sudo reboot
if that doesnt work you can try ( little more risky if you mess it up or have other media drivers youve installed )
sudo make rmmod
sudo mv /lib/modules/$(uname -r)/kernel/drivers/media ~/media.bak
sudo make install
sudo reboot
Re: 3.9 support?
Postby frednet » Thu May 16, 2013 6:26 am
Thanks but sadly it made no difference. I'm still getting the same
Code: Select all
[   26.194533] saa716x_core: disagrees about version of symbol dvb_dmxdev_init
[   26.194538] saa716x_core: Unknown symbol dvb_dmxdev_init (err -22)
[   26.194571] saa716x_core: disagrees about version of symbol dvb_register_adapter
[   26.194572] saa716x_core: Unknown symbol dvb_register_adapter (err -22)
[   26.194604] saa716x_core: disagrees about version of symbol dvb_net_init
[   26.194605] saa716x_core: Unknown symbol dvb_net_init (err -22)
[   26.194611] saa716x_core: disagrees about version of symbol dvb_dmxdev_release
[   26.194612] saa716x_core: Unknown symbol dvb_dmxdev_release (err -22)
[   26.194620] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[   26.194621] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[   26.194627] saa716x_core: disagrees about version of symbol dvb_net_release
[   26.194628] saa716x_core: Unknown symbol dvb_net_release (err -22)
[   26.194633] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[   26.194634] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[   26.194639] saa716x_core: disagrees about version of symbol dvb_register_frontend
[   26.194640] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
[   26.194645] saa716x_core: disagrees about version of symbol dvb_unregister_adapter
[   26.194646] saa716x_core: Unknown symbol dvb_unregister_adapter (err -22)
Has anyone got this working on Ubuntu 13.04 or am I the only one?
frednet
Re: 3.9 support?
Postby updatelee » Thu May 16, 2013 9:47 am
did you try my last suggestion? moving the media folder, linux-3.9 has a different folder layout, I would guess thats whats causing the issues. rminstall isnt removing all the old kernel modules because they are in a different location.
Re: 3.9 support?
Postby frednet » Fri May 17, 2013 7:10 am
Fantastic! Thanks very much, you were right about the folder layout. Shame that TBS can't produce a simple debian package for it though!
frednet
Re: 3.9 support?
Postby briogoog » Sun May 19, 2013 6:16 am
The 2nd solution to move the media folder fixed this for me too after upgrading to Ubuntu 13.04
briogoog
