TBS6985 is invisible on Dell R210 ii + xubutun 12.04/12.10
Postby axion » Wed Apr 24, 2013 2:18 am
Hi TBS gurus,
Have anyone managed to get the tbs-6985 working with Dell R210 ii?
Also tested with tbs-6284 but the same, not working. unbuntu's kernel is 3.5.0.27 and 3.2.0.26.
TBS driver download page said "They've tested on kernel 3.7".
I exactly followed the instructions from the tbs documentation during the installation.
Can you guys please help me out?
Many thanks,
axion
axion
Re: TBS6985 is invisible on Dell R210 ii + xubutun 12.04/12.
Postby bob » Wed Apr 24, 2013 2:08 pm
Please send me the log file which below steps:
'dmesg' log after driver installation (if applicable, please see 1. too):
# dmesg >> dmesg_log
* log of 'lspci' output (only if you have PCI or PCI-Expreess card):
# lspci -vvnn >> lspci_log
Regards!
bob
Postby axion » Wed Apr 24, 2013 5:18 pm
Hi Bob,
Thank you very much for the reply. Please see the attached zip files.
regards,
axion
lspci.zip
lspci log
(3.42 KiB) Downloaded 298 times
dmesg.zip
dmesg log
(13.46 KiB) Downloaded 284 times
axion
Postby n3lson » Thu May 02, 2013 11:18 pm
Got mine running fine on both 12.04 (3.2.0.40) & 12.04.2 (3.5.0.27)
From your lspci - no mention of SAA7160
from your dmesg - no pci:xxxx:xx:xx.x: [1131:7160] detection.
Looks like your motherboard isn't detecting/enabling the cards
Make sure bios is updated, and check for any weird pci or power management options in the bios.
n3lson
Postby Traveler » Sat Aug 31, 2013 12:04 am
Helo,
I have same issue, but with lspci I can see card:
01:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 02)
What can be a issue?
Traveler
