TBS + TransEdit + Stab HH90 = USALS doesn't work
Postby pazi » Thu May 16, 2013 6:26 pm
I've Stab HH90 motor and TBS6922. When I use TransEdit programme USALS commend doesn't work - I'm setting Angular Position (in the TransEdit) DiseqC option but motor doesn't move. In DVBViewer or TBS IP USALS commend works fine with the same settings. When I previously had Skystar HD2 card everything was all right in the TransEdit.
pazi
Re: TBS + TransEdit + Stab HH90 = USALS doesn't work
Postby steven » Sun May 19, 2013 3:10 pm
Hi pazi
Oh,This is TransEdit have not called the DiSEqc interface,Maybe you can write a letter to
DVBViewer to let them support this.If you are not convenience,we will try to contact them
with this. :)
Postby pazi » Fri May 24, 2013 11:33 pm
Hi Steven!
I was started new topic on DVBViewer forum http://www.dvbviewer.tv/forum/topic/525 ... esnt-work/
When I turn on the computer and run TransEdit for the first time USALS work fine and motor run, but when I want scan other Satellite motor stay. Maybe this is a issue power on/off in TBS driver
Still doesn't work and I don't have any ideas.
pazi
