ly3nml wrote:Hello, MOI use an old MuMuDVB version 1.6. I want to try 1.7.1 with software cam (SCAM) support. The SCAM support depends on libdvbcsa from videolan. Have somebody compiled required packages and tried it? Or it is not enough of CPU power for that? Excuse me for my bad EN.
ly3nml wrote:Thank you for the answer. I'm looking for the solution to decrypt and stream entire transponder (or two transponders) using MOI box and softcam. I know how to do that using linux PC with mumudvb, libdvbsca and oscam installed. I'm not sure if I can get some results using MOI.
UHDTVdreamer wrote:How do you approx Mumudvb. In de browser you only see TVHeadend.
Do you need the serial connexion?
