Tuner: TBS6981
OS: Slackware64 14.0
Kernel: 3.2.45 x86_64
Driver: v130506
I can't seem to get the TBS6981 working in Slackware64. The drivers appear to build OK, but during boot the frontend initialisation fails. I have two TBS cards in this system at the same time: TBS6981 and TBS6280. The 6280 works fine but the 6981 fails to start. This problem still happens if I remove the TBS6280 and perform the steps below.
Slackware was installed onto a freshly formatted HDD, with all packages selected during install. A full update was run via "slackpkg upgrade-all".
Then:
wget http://www.tbsdtv.com/download/document ... 130506.zip
unzip tbs-linux-drivers_v130506.zip
tar -jxf linux-tbs-drivers.tar.bz2
cd linux-tbs-drivers
./v4l/tbs-x86_64.sh
make && make install
init 6
At this point I captured the attached dmesg and lcpci outputs.
Any help is much appreciated.
Edit: Can't seem to attach files, and I can't put them into a code box because they exceed the max character limit.
