TBS 6985 dont tune
TBS 6985 dont tune
Postby angelz » Tue Aug 20, 2013 6:37 pm
Hello, I try to install tbs 6985 on linux ubuntu server 12.04 LTS 64bit
the install seem to be ok but I dont arrive to tune channel
linux version :
Code: Select all
uname -a
Linux decodeur-sat 3.5.0-39-generic #60~precise1-Ubuntu SMP Wed Aug 14 15:38:41 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
I have follow this steps to intall drivers and tools scan - szap:
    sudo aptitude update
    sudo aptitude upgrade
    mkdir driver_tbs6985
    cd driver_tbs6985
    unzip tbs-linux-drivers_v130802.zip
    cd linux-tbs-drivers/
    sudo ./v4l/tbs-x86_64.sh
    sudo make && sudo make install
    sudo shutdown -r now
    cd ..
    tar xjvf szap-s2.tar.bz2
    cd szap-s2
    sudo make
    sudo make install
    cd ..
    tar xjvf scan-s2.tar.bz2
    cd scan-s2
    sudo make
    sudo make install
after this in dmesg I see this :
Code: Select all
dmesg | grep frontend
[    2.675672] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
[    3.228796] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
[    3.780790] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
[    4.332797] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
Code: Select all
dmesg > dmesg.log
https://dl.dropboxusercontent.com/u/108493444/dmesg.log
Code: Select all
lspci -vvnn >> lspci_log
https://dl.dropboxusercontent.com/u/108493444/lspci_log
where I test with scan-s2 :
Code: Select all
sudo scan-s2 -a 0 astra_scan-s2.conf
API major 5, minor 3
ERROR: Cannot open rotor configuration file 'rotor.conf'.
scanning astra_scan-s2.conf
initial transponder DVB-S  10773000 H 22000000 5/6 35 QPSK
initial transponder DVB-S  11778000 V 27500000 3/4 35 QPSK
initial transponder DVB-S2 11362000 H 22000000 2/3 35 8PSK
>>> tune to: 10773:hC56M2O35S0:S0.0W:22000:
DVB-S IF freq is 1023000
WARNING: >>> tuning failed!!!
>>> tune to: 10773:hC56M2O35S0:S0.0W:22000: (tuning failed)
>>> tune to: 11778:vC34M2O35S0:S0.0W:27500:
DVB-S IF freq is 1178000
>>> tune to: 11778:vC34M2O35S0:S0.0W:27500: (tuning failed)
----------------------------------> Using DVB-S2
>>> tune to: 11362:hC23M5O35S1:S0.0W:22000:
DVB-S IF freq is 1612000
>>> tune to: 11362:hC23M5O35S1:S0.0W:22000: (tuning failed)
ERROR: initial tuning failed
dumping lists (0 services)
Done.
Code: Select all
cat astra_scan-s2.conf
S1 10773000 H 22000000 5/6 35 QPSK
S1 11778000 V 27500000 3/4 35 QPSK
my kernel.log
Code: Select all
sudo cat /var/log/kern.log > kernel.log
https://dl.dropboxusercontent.com/u/108493444/kernel.log
the goal is to se this card with tvheadend.
please someone can help me ?
thanks
angelz
Re: TBS 6985 dont tune
Postby updatelee » Tue Aug 20, 2013 8:43 pm
I dont use scan-s2, but do you have the same default lnb as scan-s2? maybe you need to change that. Im sure there is a command line option for it. What about switch's? no switch's in your setup? Are those three tp valid for whatever satellite your tuning ?
Postby angelz » Tue Aug 20, 2013 9:11 pm
hello,
I have no switch in the setup I have a lnb 4 out as this (astra/hotbird):
not tis product but same system
when I put the cable of one of 4 out in my dreambox all is ok I receive and scan (with dreabox) all channel but when I plug the same cable to my linux tune fail ...
I dont see what do you say for option for scan-s2
witch Tools do you use for testind scan channel.
I have try w-scan dvb-tools scan scan-s2 always same result :
tune fail
thanks for help
angelz
Postby angelz » Tue Aug 20, 2013 9:13 pm
the scan-s2 help :
Code: Select all
scan-s2
initial tuning data files:
usage: scan-s2 [options...] [-c | initial-tuning-data-file]
        atsc/dvbscan doesn't do frequency scans, hence it needs initial
        tuning data for at least one transponder/channel.
        -c      scan on currently tuned transponder only
        -v      verbose (repeat for more)
        -q      quiet (repeat for less)
        -a N    use DVB /dev/dvb/adapterN/
        -f N    use DVB /dev/dvb/adapter?/frontendN
        -d N    use DVB /dev/dvb/adapter?/demuxN
        -s N    use DiSEqC switch position N (DVB-S only)
        -S N    use DiSEqC uncommitted switch position N (DVB-S only)
        -r sat  move DiSEqC rotor to satellite location, e.g. '13.0E' or '1.0W'
        -R N    move DiSEqC rotor to position number N
        -i N    spectral inversion setting (0: off, 1: on, 2: auto [default])
        -n      evaluate NIT messages for full network scan (slow!)
        -5      multiply all filter timeouts by factor 5
                for non-DVB-compliant section repitition rates
        -O pos  Orbital position override 'S4W', 'S19.2E' - good for VDR output
        -k cnt  Skip count: skip the first cnt
                messages of each message type (default 0)
        -I cnt  Scan iterations count (default 10).
                Larger number will make scan longer on every channel
        -o fmt  output format: 'vdr' (default), 'vdr16x' for VDR version 1.6.x or 'zap'
        -x N    Conditional Access, (default -1)
                N=-2  gets all channels (FTA and encrypted),
                      output received CAID :CAID:
                N=-1  gets all channels (FTA and encrypted),
                      output CA is set to :0:
                N=0   gets only FTA channels
                N=xxx  sets ca field in vdr output to :xxx:
        -t N  Service select, Combined bitfield parameter.
                1 = TV, 2 = Radio, 4 = Other, (default 7)
        -p      for vdr output format: dump provider name
        -e N  VDR version, default 2 for VDR-1.2.x
                ANYTHING ELSE GIVES NONZERO NIT and TID
                Vdr version 1.3.x and up implies -p.
        -l lnb-type (DVB-S Only) (use -l help to print types) or
        -l low[,high[,switch]] in Mhz
        -u UK DVB-T Freeview channel numbering for VDR
        -P do not use ATSC PSIP tables for scanning
            (but only PAT and PMT) (applies for ATSC only)
        -A N    check for ATSC 1=Terrestrial [default], 2=Cable or 3=both
        -U      Uniquely name unknown services
        -D s    Disable specified scan mode (by default all modes are enabled)
                s=S1  Disable DVB-S scan
                s=S2  Disable DVB-S2 scan (good for owners of cards that do not
                      support DVB-S2 systems)
        -X      Disable AUTOs for initial transponders (esp. for hardware which
                not support it). Instead try each value of any free parameters.
angelz
Postby angelz » Tue Aug 20, 2013 9:23 pm
if i use scan-s2 with verbose :
Code: Select all
sudo scan-s2 -a 0  astra_scan-s2.conf -v
DiSEqC: uncommitted switch pos 0
DiSEqC: switch pos 0, 18V, loband (index 1)
>>> tuning status == 0x00
DiSEqC: switch pos 0, 13V, hiband (index 2)
Done.
maybe more info for you
angelz
Postby angelz » Wed Aug 21, 2013 4:39 pm
hello,
nobody has any idea?
it's been a month that I look for a solution to this problem and I do not see anywhere on the internet for info
tbs team you have an idea?
angelz
Postby stilmant » Wed Aug 21, 2013 5:14 pm
My two cents, never used scan-s2
I would wonder about:
"ERROR: Cannot open rotor configuration file 'rotor.conf'." but this is maybe "normal" in scan-s2.
maybe also this is important?
can you try with w_scan tool?
http://wirbel.htpc-forum.de/w_scan/index2.html
stilmant
Postby angelz » Wed Aug 21, 2013 5:33 pm
i have try w-scan but dont works
Code: Select all
sudo w_scan -f s -s S19E2 -x
w_scan version 20111203 (compiled for DVB API 5.4)
using settings for 19.2 east Astra 1F/1G/1H/1KR/1L
frontend_type DVB-S, channellist 6
output format initial tuning data
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
        /dev/dvb/adapter0/frontend0 -> DVB-S "TurboSight TBS 6985 DVBS/S2 frontend": very good :-))
Using DVB-S frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.3
frontend 'TurboSight TBS 6985 DVBS/S2 frontend' supports
INVERSION_AUTO
DVB-S
DVB-S2
FREQ (0.95GHz ... 2.15GHz)
SRATE (1.000MBd ... 45.000MBd)
using LNB "UNIVERSAL"
(time: 00:00)
(time: 00:05)
(time: 00:10)
(time: 00:14)
(time: 00:19)
(time: 00:24)
(time: 00:28)
(time: 00:33)
(time: 00:38)
(time: 00:43)
(time: 00:47)
(time: 00:52)
(time: 00:57)
(time: 01:02)
(time: 01:06)
(time: 01:11)
(time: 01:16)
(time: 01:21)
(time: 01:25)
(time: 01:30)
(time: 01:35)
(time: 01:40)
(time: 01:44)
(time: 01:49)
(time: 01:54)
(time: 01:59)
(time: 02:03)
(time: 02:08)
(time: 02:13)
(time: 02:18)
(time: 02:22)
(time: 02:27)
(time: 02:32)
(time: 02:37)
(time: 02:41)
(time: 02:46)
(time: 02:51)
(time: 02:56)
(time: 03:00)
(time: 03:05)
(time: 03:10)
(time: 03:15)
(time: 03:19)
(time: 03:24)
(time: 03:29)
(time: 03:34)
(time: 03:38)
(time: 03:43)
(time: 03:48)
(time: 03:53)
(time: 03:57)
(time: 04:02)
(time: 04:07)
(time: 04:12)
(time: 04:16)
(time: 04:21)
(time: 04:26)
(time: 04:31)
(time: 04:35)
(time: 04:40)
(time: 04:45)
(time: 04:50)
(time: 04:54)
(time: 04:59)
(time: 05:04)
(time: 05:09)
(time: 05:13)
(time: 05:18)
(time: 05:23)
(time: 05:28)
(time: 05:32)
(time: 05:37)
(time: 05:42)
(time: 05:47)
(time: 05:51)
(time: 05:56)
(time: 06:01)
(time: 06:06)
(time: 06:10)
(time: 06:15)
(time: 06:20)
(time: 06:25)
(time: 06:29)
(time: 06:34)
(time: 06:39)
(time: 06:44)
(time: 06:48)
(time: 06:53)
(time: 06:58)
(time: 07:03)
(time: 07:07)
(time: 07:12)
(time: 07:17)
(time: 07:22)
(time: 07:26)
(time: 07:31)
(time: 07:36)
(time: 07:41)
(time: 07:45)
(time: 07:50)
(time: 07:55)
(time: 08:00)
(time: 08:04)
(time: 08:09)
(time: 08:14)
(time: 08:19)
(time: 08:23)
(time: 08:28)
(time: 08:33)
(time: 08:38)
(time: 08:42)
(time: 08:47)
(time: 08:52)
(time: 08:57)
(time: 09:01)
(time: 09:06)
(time: 09:11)
(time: 09:16)
(time: 09:20)
(time: 09:25)
ERROR: Sorry - i couldn't get any working frequency/transponder
 Nothing to scan!!
this log say you something?
angelz
Postby stilmant » Wed Aug 21, 2013 9:55 pm
I can't help you more. you have to take care to
following log from w_scan: >using LNB "UNIVERSAL"< like updatelee was saying for you to select correct LNB settings.
look here for other possible values: http://www.austech.info/other-hardware/ ... 700-a.html (first link found using google, not directly related to issue)
but first, have you connected the Tuner Card Extra power connector?
second, you have 4 tuner entries, are you connecting stuff to adapter 0?
good luck
stilmant
Postby LubosD » Thu Sep 05, 2013 5:45 pm
Hi, I also have trouble tuning with TBS 6985. w_scan works like a charm while scan-s2 fails to tune anything.
When I switch the sat cable into another DVB-S card, then scan-s2 works again. So this must be some sort of compatibility problem between scan-s2 and drivers for TBS 6985.
LubosD
