Firmware 1.21 + MuMuDVB = Segmentation fault
Postby Traveler » Tue Aug 27, 2013 12:32 am
Hello to everybody,
After upgrading my MOI Box with latest release of Firmware 1.2.1, each time when I start MuMuDVB 1.7.1 on MOI I have segmentation fault. Does anybody have any kind of solution, because this is really annoying :(
Here is my log:
Code: Select all
# mumudvb -d -c /home/mumudvb/Tuner2-HotBird.conf
MuMuDVB Version 1.7.1
 --- Build information ---
Built with CAM support.
Built without transcoding support.
Built with ATSC support.
Built with ATSC long channel names support.
Built with support for DVB API Version 5.
Originally based on dvbstream 0.6 by (C) Dave Chapman 2001-2004
Released under the GPL.
Latest version available from http://mumudvb.braice.net/
Project from the [email protected] (http://www.crans.org)
by Brice DUBOST ([email protected])
Info:  Main:  Full autoconfiguration, we activate SAP announces. if you want to deactivate them see the README.
Info:  Main:  Full autoconfiguration, we activate PAT rewritting. if you want to deactivate it see the README.
Info:  Main:  Full autoconfiguration, we activate SDT rewritting. if you want to deactivate it see the README.
Info:  Main:  Full autoconfiguration, we activate sorting of the EIT PID. if you want to deactivate it see the README.
Info:  Main:  ========== End of configuration, MuMuDVB version 1.7.1 is starting ==========
Info:  Autoconf:  The autoconfiguration auto update is enabled. If you want to disable it put "autoconf_pid_update=0" in your config file.
Info:  Main:  Streaming. Freq 12596000
Info:  Tune:  Using DVB card "TurboSight TBS 2991 DVBS/S2 frontend" tuner 0
Info:  Tune:  Tuning DVB-S to Freq: 1996000 kHz, LO frequency 10600000 kHz Pol:V Srate=27500000, LNB number: 4
Info:  Tune:  LNB voltage 13V
Info:  Tune:  DISEQC SETTING SUCCEDED
Info:  Tune:  FE_STATUS:
Info:  Tune:       FE_HAS_SIGNAL : found something above the noise level
Info:  Tune:       FE_HAS_CARRIER : found a DVB signal
Info:  Tune:       FE_HAS_VITERBI : FEC is stable
Info:  Tune:       FE_HAS_SYNC : found sync bytes
Info:  Tune:       FE_HAS_LOCK : everything's working...
Info:  Tune:  Event:  Frequency: 12596000 (or 8604000)
Info:  Tune:          SymbolRate: 2848000
Info:  Tune:          FEC_inner:  2
Info:  Tune:  Bit error rate: 67108863
Info:  Tune:  Signal strength: 33975
Info:  Tune:  SNR: 4369
Info:  Main:  Card 1, tuner 0 tuned
Info:  Autoconf:  Autoconfiguration Start
Segmentation fault
Traveler
Re: Firmware 1.21 + MuMuDVB = Segmentation fault
Postby 0blar » Tue Dec 31, 2013 3:25 pm
Hello
I have similar problem using 2.0.2 firmware
Did you find a solution ?
0blar
Postby mdx » Fri Feb 14, 2014 10:19 am
Me too. Segmentation fault after autoconfiguration starts.
mdx
Postby pispi » Thu Oct 16, 2014 2:03 am
i have this problem too, anybody its solve this?
pispi
Postby diabloss » Sun Oct 19, 2014 2:22 pm
Guys
Make the mumu binary 755 permission wise and fill the .conf file with care.
Each mumu version have some slight small changes.
1 bad parameter in the conf file and voila ... segmentation fault.
diabloss
Return to General discussion
