No DVB-C
No DVB-C
Postby florian » Sun Sep 29, 2013 9:15 pm
Hallo,
I've problems to get DVB-C work on my system.
1. The driver for TBS5220 at tbsdtv.com compiles with error "No rule to make target .... tbs8921ctrl.o"
2. My seller gave me this link http://support.tbs-technology.de/downloads/
This is the same driver from 09 Sep 2013, but with a setup script and DVB-C is supposedly activated / supported.
The driver compiles and DVB-T works, but DVB-C not.
It seems like there is only DVB-T mode enabled? How can I make this work?
Thank you for help :mrgreen:
Provider: Kabeldeutschland
Here is some output from dvb-apps and other:
Code: Select all
 uname -a
Linux laptopHP.local 3.10.12-100.fc18.x86_64 #1 SMP Mon Sep 16 13:05:36 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
Code: Select all
 dmesg
[   17.564918] dvb-usb: found a 'TBS 5220 USB2.0' in cold state, will try to load a firmware
[   17.609728] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5220.fw'
[   17.734202] dvb-usb: found a 'TBS 5220 USB2.0' in warm state.
[   17.734378] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[   17.734451] DVB: registering new adapter (TBS 5220 USB2.0)
[   17.734470] dvb-usb: MAC address reading failed.
[   17.999660] dvb-usb: no frontend was attached by 'TBS 5220 USB2.0'
[   18.000053] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:12.2/usb1/1-3/input/input13
[   18.001071] dvb-usb: schedule remote query interval to 150 msecs.
[   18.001086] dvb-usb: TBS 5220 USB2.0 successfully initialized and connected.
[   18.010597] dvb-usb: TBS 5220 USB2.0 successfully deinitialized and disconnected.
[   19.491024] dvb-usb: found a 'TBS 5220 USB2.0' in cold state, will try to load a firmware
[   19.491161] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5220.fw'
[   19.612965] dvb-usb: found a 'TBS 5220 USB2.0' in warm state.
[   19.613143] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[   19.613453] DVB: registering new adapter (TBS 5220 USB2.0)
[   19.891200] dvb-usb: MAC address: ff:ff:ff:ff:ff:ff
[   19.956075] DVB: registering adapter 0 frontend 0 (TurboSight TBS 5220 DVBT/T2 frontend)...
[   19.958101] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:12.2/usb1/1-3/input/input14
[   19.958299] dvb-usb: schedule remote query interval to 150 msecs.
[   19.958314] dvb-usb: TBS 5220 USB2.0 successfully initialized and connected.
Code: Select all
lsusb -v -d 734c:5220
Bus 001 Device 004: ID 734c:5220 TBS Technologies China
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x734c TBS Technologies China
  idProduct          0x5220
  bcdDevice            0.01
  iManufacturer           1
  iProduct                2
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass      0
      bInterfaceProtocol      0
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Code: Select all
lsmod
dvb_usb_tbs5220        17549  0
dvb_usb                27822  1 dvb_usb_tbs5220
dvb_core              107648  1 dvb_usb
rc_core                25830  8 ir_lirc_codec,ir_rc5_decoder,dvb_usb,ir_nec_decoder,ir_sony_decoder,ir_mce_kbd_decoder,ir_jvc_decoder,ir_rc6_decoder
i2c_core               38420  8 drm,i2c_piix4,tbs5220fe,dvb_usb,drm_kms_helper,i2c_algo_bit,radeon,videodev
Code: Select all
content of /dev/dvb
ls /dev/dvb/
adapter0
ls /dev/dvb/adapter0
demux0  dvr0  frontend0  net0
Code: Select all
lsdvb
                Version: 0.0.4
                Copyright (C) Manu Abraham
usb (-2076040536:59 -509615776:32767) on PCI Domain:-2070212512 Bus:59 Device:-509615656 Function:32767
        DEVICE:0 ADAPTER:0 FRONTEND:0 (TurboSight TBS 5220 DVBT/T2 frontend)
                FE_OFDM Fmin=42MHz Fmax=1002MHz
Code: Select all
Custom dvb-c.conf for channel scan
C 113000000 6900000 NONE QAM64
C 121000000 6900000 NONE QAM64
C 322000000 6900000 NONE QAM256
C 346000000 6900000 NONE QAM64
C 354000000 6900000 NONE QAM64
C 362000000 6900000 NONE QAM64
C 370000000 6900000 NONE QAM64
C 378000000 6900000 NONE QAM64
C 386000000 6900000 NONE QAM64
C 394000000 6900000 NONE QAM64
C 402000000 6900000 NONE QAM64
C 410000000 6900000 NONE QAM64
C 418000000 6900000 NONE QAM64
C 426000000 6900000 NONE QAM64
C 434000000 6900000 NONE QAM64
C 442000000 6900000 NONE QAM64
C 450000000 6900000 NONE QAM64
C 458000000 6900000 NONE QAM256
C 466000000 6900000 NONE QAM64
C 482000000 6900000 NONE QAM64
C 490000000 6900000 NONE QAM256
Code: Select all
some channels from inofficial channels.conf for my location
ZDF:346000:M64:C:6900:110:120=deu,121=2ch;125=dd:130:0:28006:1:1079:0
3sat:346000:M64:C:6900:210:220=deu,221=2ch;225=dd:230:0:28007:1:1079:0
ZDFdokukanal:346000:M64:C:6900:660:670=deu:630:0:28014:1:1079:0
Code: Select all
dvb-fe-tool
Device TurboSight TBS 5220 DVBT/T2 frontend (/dev/dvb/adapter0/frontend0) capabilities:
   CAN_FEC_1_2 CAN_FEC_2_3 CAN_FEC_3_4 CAN_FEC_4_5 CAN_FEC_5_6 CAN_FEC_7_8 CAN_FEC_AUTO CAN_GUARD_INTERVAL_AUTO CAN_HIERARCHY_AUTO CAN_INVERSION_AUTO CAN_QAM_16 CAN_QAM_32 CAN_QAM_64 CAN_QAM_128 CAN_QAM_256 CAN_QAM_AUTO CAN_QPSK CAN_RECOVER CAN_TRANSMISSION_MODE_AUTO
DVB API Version 5.3, Current v5 delivery system: DVBT
Supported delivery system: [DVBT]
Warning: ISDB-T, ISDB-S, DMB-TH and DSS will be miss-detected by a DVBv3 call
Code: Select all
czap -c channels.conf -H ZDF
reading channels from file 'channels.conf'
 26 ZDF:346000:M64:C:6900:110:120=deu,121=2ch;125=dd:130:0:28006:1:1079:0
ERROR: cannot parse service data
Code: Select all
scandvb custom freq
scandvb dvb-c.conf > scandvb.txt
scanning dvb-c.conf
initial transponder 442000000 6900000 0 5
....... cut .................
>>> tune to: 490000000:INVERSION_AUTO:6900000:FEC_NONE:QAM_256
WARNING: >>> tuning failed!!!
>>> tune to: 490000000:INVERSION_AUTO:6900000:FEC_NONE:QAM_256 (tuning failed)
ERROR: initial tuning failed
dumping lists (0 services)
Done.
Code: Select all
scandvb with freq from dvb-apps package
scandvb /usr/share/dvb/dvb-c/de-Muenchen
scanning /usr/share/dvb/dvb-c/de-Muenchen
initial transponder 113000000 6900000 0 3
........... cut .................
Done.
Code: Select all
w_scan initial data
w_scan -fc -c DE -x >> w_scan_initial_data.txt
w_scan version 20130331 (compiled for DVB API 5.9)
using settings for GERMANY
DVB cable
DVB-C
scan type CABLE, channellist 7
output format initial tuning data
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
        /dev/dvb/adapter0/frontend0 -> CABLE "TurboSight TBS 5220 DVBT/T2 frontend": good :-)
Using CABLE frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.3
frontend 'TurboSight TBS 5220 DVBT/T2 frontend' supports
INVERSION_AUTO
QAM_AUTO
FEC_AUTO
FREQ (42.00MHz ... 1002.00MHz)
This dvb driver is *buggy*: the symbol rate limits are undefined - please report to linuxtv.org
73000: sr6900 (time: 00:00) sr6875 (time: 00:04)
81000: sr6900 (time: 00:09) sr6875 (time: 00:14)
850000: sr6900 (time: 24:35) sr6875 (time: 24:40)
858000: sr6900 (time: 24:45) sr6875 (time: 24:49)
ERROR: Sorry - i couldn't get any working frequency/transponder
 Nothing to scan!!
Code: Select all
femon signal quality
femon -H
FE: TurboSight TBS 5220 DVBT/T2 frontend (DVBT)
status       | signal  96% | snr   0% | ber 1 | unc 0 |
.... cut ....
status       | signal  95% | snr   0% | ber 1 | unc 0 |
florian
Re: No DVB-C
Postby stilmant » Tue Oct 01, 2013 4:42 pm
hello,
from read me I read the following
in case you want to use 5220 for DVBC then before step I.4 (and after I.3) from the
steps in II. run:
- for x86 kernel 3.x (x86 32 bit installations of kernel 3.x):
Did you done that step?
stilmant
Re: No DVB-C
Postby florian » Thu Oct 03, 2013 8:40 pm
this is what I did:
extract linux-tbs-drivers.tar.bz2 (with Ark under KDE)
copy the firmware files to /lib/firmware
execute ./v4l/tbs-x86_64.sh (commandline)
execute ./v4l/tbs-dvb-c.x86_64.sh (commandline)
make -> here comes the error "No rule to make target .... tbs8921ctrl.o" (commandline)
all commands as root
this is what I did yesterday:
download the driver package again
remove the old tbs-driver directory
extract linux-tbs-drivers.tar.bz2 (commandline with tar xjvf linux-tbs-drivers.tar.bz2 - this was different)
make (no errors)
make install
and it works :D
maybe there is a problem with Ark?
The drivers from tbs-technology.de didn't work with DVB-C. The Script don't execute tbs-dvb-c.x86_64.sh.
Thanke you that was the problem with this driver :D
But now I do have another "problem". When I compile the dvb-c driver, the dvb-t mode is not available. Is this supposed to happen? Is a dual mode planned?
florian
Re: No DVB-C
Postby stilmant » Thu Oct 03, 2013 10:25 pm
Would like to know that too.
stilmant
Re: No DVB-C
Postby bolzerrr » Thu Nov 21, 2013 4:47 am
HI,
can you please tell me what driver exactly you took (link)?
I think i have a similar problem. When i try a to tune nothing happens.
I compiled successfully (debian linux)
dmesg
Code: Select all
[49168.175314] dvb-usb: found a 'TBS 5220 USB2.0' in cold state, will try to loa        d a firmware
[49168.223004] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5220.f        w'
[49168.230495] tbs5220: start downloading TBS5220 firmware
[49168.358289] dvb-usb: found a 'TBS 5220 USB2.0' in warm state.
[49168.370325] dvb-usb: will pass the complete MPEG2 transport stream to the sof        tware demuxer.
[49168.379669] DVB: registering new adapter (TBS 5220 USB2.0)
[49168.628276] dvb-usb: MAC address: ff:ff:ff:ff:ff:ff
[49168.720606] tbs5220: Attached TBS5220FE!
[49168.720612]
[49168.726228] DVB: registering adapter 0 frontend 0 (TurboSight TBS 5220 DVBC f        rontend)...
[49168.735672] input: IR-receiver inside an USB DVB receiver as /devices/pci0000        :00/0000:00:01.0/0000:01:0d.0/usb1/1-1/input/input1
[49168.749753] dvb-usb: schedule remote query interval to 150 msecs.
[49168.755917] dvb-usb: TBS 5220 USB2.0 successfully initialized and connected.
[49194.730030] TurboSight TBS 5220 Frontend:
[49194.730035]  tbs5220fe - software version is 1.0.0.0
[49194.846968] TurboSight TBS 5220 Frontend:
[49194.846974]  tbs5220fe - Successfully Initialized
lsmod | grep dvb
Code: Select all
lsmod | grep dvb
dvb_usb_tbs5220         6292  0
dvb_usb                16658  1 dvb_usb_tbs5220
rc_core                12810  1 dvb_usb
dvb_ttpci              84191  0
saa7146_vv             38777  1 dvb_ttpci
ttpci_eeprom            1300  1 dvb_ttpci
saa7146                12583  2 saa7146_vv,dvb_ttpci
dvb_core               73865  2 dvb_ttpci,dvb_usb
usbcore               137247  11 ehci_hcd,xhci_hcd,etxhci_hcd,uhci_hcd,usb_storage,usblp,usbhid,dvb_usb,dvb_usb_tbs5220
Code: Select all
  2 ZDF:346000:M64:C:6900:110:120=deu,121=2ch;125=dd:130:0:28006:1:1079:0
Code: Select all
 w_scan -fc -cDE
w_scan version 20130331 (compiled for DVB API 5.4)
DVB cable
DVB-C
output format vdr-2.0
WARNING: could not guess your codepage. Falling back to 'UTF-8'
        /dev/dvb/adapter0/frontend0 -> CABLE "TurboSight TBS 5220 DVBC frontend": good :-)
Using DVB API 5.3
frontend 'TurboSight TBS 5220 DVBC frontend' supports
INVERSION_AUTO
QAM_AUTO
FEC_AUTO not supported, trying FEC_NONE.
SRATE (1.000MSym/s ... 7.200MSym/s)
73000: sr6900 (time: 00:00) sr6875 (time: 00:02)
81000: sr6900 (time: 00:05) sr6875 (time: 00:07)
113000: sr6900 (time: 00:10) (time: 00:11) signal ok:
        QAM_AUTO f = 113000 kHz S6900C0
After this Line nothing happens anymode: QAM_AUTO f = 113000 kHz S6900C0
VDR cannot tune any channels..
What i found in build log :
Code: Select all
  LD [M]  /usr/local/src/tbs/linux-tbs-drivers/v4l/ngene.o
  LD [M]  /usr/local/src/tbs/linux-tbs-drivers/v4l/ddbridge.o
  Building modules, stage 2.
  MODPOST 502 modules
WARNING: could not find /usr/local/src/tbs/linux-tbs-drivers/v4l/.tbs8921ctrl.o.cmd for /usr/local/src/tbs/linux-tbs-drivers/v4l/tbs8921ctrl.o
WARNING: could not find /usr/local/src/tbs/linux-tbs-drivers/v4l/.tbs5220ctrl.o.cmd for /usr/local/src/tbs/linux-tbs-drivers/v4l/tbs5220ctrl.o
WARNING: could not find /usr/local/src/tbs/linux-tbs-drivers/v4l/.tbs5680ctrl.o.cmd for /usr/local/src/tbs/linux-tbs-drivers/v4l/tbs5680ctrl.o
WARNING: could not find /usr/local/src/tbs/linux-tbs-drivers/v4l/.tbs5880ctrl.o.cmd for /usr/local/src/tbs/linux-tbs-drivers/v4l/tbs5880ctrl.o
WARNING: could not find /usr/local/src/tbs/linux-tbs-drivers/v4l/.tbs5881ctrl.o.cmd for /usr/local/src/tbs/linux-tbs-drivers/v4l/tbs5881ctrl.o
WARNING: could not find /usr/local/src/tbs/linux-tbs-drivers/v4l/.tbs5925ctrl.o.cmd for /usr/local/src/tbs/linux-tbs-drivers/v4l/tbs5925ctrl.o
WARNING: could not find /usr/local/src/tbs/linux-tbs-drivers/v4l/.tbsdvbcctrl.o.cmd for /usr/local/src/tbs/linux-tbs-drivers/v4l/tbsdvbcctrl.o
WARNING: could not find /usr/local/src/tbs/linux-tbs-drivers/v4l/.tbs5922ctrl.o.cmd for /usr/local/src/tbs/linux-tbs-drivers/v4l/tbs5922ctrl.o
WARNING: could not find /usr/local/src/tbs/linux-tbs-drivers/v4l/.tbs5921ctrl.o.cmd for /usr/local/src/tbs/linux-tbs-drivers/v4l/tbs5921ctrl.o
  CC      /usr/local/src/tbs/linux-tbs-drivers/v4l/adp1653.mod.o
  LD [M]  /usr/local/src/tbs/linux-tbs-drivers/v4l/adp1653.ko
bolzerrr
Re: No DVB-C
Postby updatelee » Thu Nov 21, 2013 7:17 am
ignore the
and
"WARNING: could not find /usr/local/src/tbs/linux-tbs-drivers/v4l/.tbs8921ctrl.o.cmd"
warnings, they arent errors. The kernel is just confused because its used to compiling source code, those files are precompiled by TBS so there is no source code. Its not an issue.
As to why DVB-C isnt working and DVB-T is I havent a clue, I live in NA and those formats are not used here so I dont have a card supporting either.
Re: No DVB-C
Postby cody » Thu Nov 21, 2013 5:44 pm
Hi, please, post here or send me to our support emails your channels.conf file.
also, can you lock DVB-T/T2 signal - that just to rule out your 5220 stick is operational and not faulty?
Re: No DVB-C
Postby bolzerrr » Thu Nov 21, 2013 9:18 pm
i took this channels.conf wich fits my region:
http://www.vdr-wiki.de/wiki/index.php/C ... UnityMedia
Annd made a test file:
ZDF:394000:C0M256:C:6900:110:120=deu,121=2ch;125=deu:130:0:28006:102:1079:0
I compile currently the dvb-t driver, test will follow
bolzerrr
Re: No DVB-C
Postby bolzerrr » Thu Nov 21, 2013 10:33 pm
Here is the result with canning in DVB-T, same issue when first channel is found the scan stopps:
w_scan
WARNING: could not guess your country. Falling back to 'DE'
guessing country 'DE', use -c <country> to override
DVB aerial
DVB-T Europe
scan type TERRESTRIAL, channellist 4
/dev/dvb/adapter0/frontend0 -> TERRESTRIAL "TurboSight TBS 5220 DVBT/T2 frontend": good :-)
Using TERRESTRIAL frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.3
INVERSION_AUTO
QAM_AUTO
GUARD_INTERVAL_AUTO
HIERARCHY_AUTO
FEC_AUTO
Scanning 7MHz frequencies...
177500: (time: 00:04)
184500: (time: 00:09)
191500: (time: 00:14)
198500: (time: 00:18)
205500: (time: 00:23)
212500: (time: 00:28)
219500: (time: 00:33)
226500: (time: 00:37)
Scanning 8MHz frequencies...
474000: (time: 00:42)
482000: (time: 00:47) (time: 00:48) signal ok:
QAM_AUTO f = 482000 kHz I999B8C999D999T999G999Y999
EDIT:
2 bought 2 USB Adapters, so i opend the second and tried with the same result- so i would say it is not a hardware defect- or 2 of them
EDIT2:
usinf the wirbelscan plugin i get this output:
vdr: [18586] ERROR: can't open filter handle on '/dev/dvb/adapter0/demux0'
ERROR (dvbdevice.c,1071): /dev/dvb/adapter0/demux0: No such device
ERROR (dvbdevice.c,1379): No such device
ERROR: can't set PID 99 on device 1
So the demux doent seem to work.
but it seems to be there:
ll /dev/dvb/adapter0/demux0
crw-rw-rw- 1 root root 212, 4 Nov 14 10:41 /dev/dvb/adapter0/demux0
UPDATE 3
TVHEADEND 3
webui: Stop streaming /stream/mux/_dev_dvb_adapter0_TurboSight_TBS_5220_DVBC_frontend354000000, timeout waiting for packets
UPDATE4
maybe also intresing if i try to steam :
[ 2504.699297] DVB: adapter 0 frontend 0 symbol rate 6 out of range (1000000..7200000)
[ 2664.258844] DVB: adapter 0 frontend 0 symbol rate 6 out of range (1000000..7200000)
[ 2681.927078] DVB: adapter 0 frontend 0 symbol rate 6 out of range (1000000..7200000)
Can someone give me a list of requires modules for this stick?
bolzerrr
Re: No DVB-C
Postby bolzerrr » Wed Nov 27, 2013 9:40 pm
I finally got it working. Important:
- Stick cannot run on a USB3 Port (gives a wrong IRQ assignments message in dmesg)
- I Have to restart the udev service. Found this hint here http://linuxtv.org/wiki/index.php/DVB_via_USB#Firmware
Maybe it will help others.
bolzerrr
