Descramble whole transponder and stream
Postby ashuprabhaker » Fri Nov 01, 2013 6:46 am
Hi , I trying to setup to stream two scrambled transponder , was reading that its possible to do it using oscam , can anyone please help me with small guide.
ashuprabhaker
Re: Descramble whole transponder and stream
Postby updatelee » Fri Nov 01, 2013 9:31 am
It's pretty easy to stream an entire tp in Linux. I don't know anything at all about decrypting it though
Postby ashuprabhaker » Fri Nov 01, 2013 11:31 am
Plz any guide to stream two transponder will be helpful even for fta channels
I saw a post that its possible to descramble it using oscam.
ashuprabhaker
Postby updatelee » Fri Nov 01, 2013 8:18 pm
It would be helpful to know what your trying to accomplish first. Are you streaming from one PC to another? Same home network? Over the internet? What's the bandwidth of your network between the two computers? What's the bandwidth of each of the tp?
Postby ashuprabhaker » Sat Nov 02, 2013 5:04 pm
updatelee wrote:It would be helpful to know what your trying to accomplish first. Are you streaming from one PC to another? Same home network? Over the internet? What's the bandwidth of your network between the two computers? What's the bandwidth of each of the tp?
Got two dual tuner dvbs2 cards , trying to stream two fta transponders and two scrambled transponders to internet ,10 channels on every transponder
, got 100 mbps line up and down so uploading wont be problem .
Just looking for plain guide to stream transponders to internet.
ashuprabhaker
Postby updatelee » Sun Nov 03, 2013 10:44 pm
I don't know about in euro but many tp here in NA you'd be hard presses to stream two tp.
My app, updateDVB, will stream select pids or an entire tp no problem. You could write an app no problem. Its pretty simple, open the demux read it and write to a network socket.
Postby ashuprabhaker » Tue Nov 05, 2013 4:01 pm
updatelee wrote:I don't know about in euro but many tp here in NA you'd be hard presses to stream two tp.
I wish to be that smart to write apps for my self, not that smart to write but can follow a guide if anyone can provide .
ashuprabhaker
Postby updatelee » Wed Nov 06, 2013 12:11 am
You could prob use tvheadend or mumudvb
