Enable crontab
Enable crontab
Postby qvindesland » Tue Dec 17, 2013 8:07 pm
I made a script to check that checks my sd card is mounted as i need it for store the temp files so we can rewind and pause but when I do crontab -e I get crontab: chdir(/var/spool/cron/crontabs): No such file or directory suggesting that crontab is installed but not enabled, how would I enable crontab?
Regards
Per
qvindesland
Re: Enable crontab
Postby Fant » Wed Sep 24, 2014 3:47 am
I can not make a working crontab.
Prompt how to make the right to work crontab?
What am I doing wrong?
[email protected]:/# date
Wed Sep 24 03:41:53 CST 2014
[email protected]:/# uptime
03:42:01 up 21 days, 1:24, load average: 0.00, 0.00, 0.00
Wed Sep 24 03:42:07 CST 2014
[email protected]:/# crontab -l
43 03 * * * root reboot
Wed Sep 24 03:42:30 CST 2014
03:42:41 up 21 days, 1:25, load average: 0.00, 0.00, 0.00
03:43:05 up 21 days, 1:25, load average: 0.00, 0.00, 0.00
03:44:03 up 21 days, 1:26, load average: 0.00, 0.00, 0.00
In 03:43 system not rebooting.
Why ?
Fant
Re: Enable crontab
Postby zhangchao » Wed Sep 24, 2014 11:21 am
hello ,
i'm sorry to give the reply for delay.
if you want to use crontab, you can refer to this :
1. login moi+ via ssh :
# cat /root/cron/root
*/1 * * * * /root/monitoring-script.sh
*/1 * * * * /root/monitoring-script.sh" mean run
"/root/monitoring-script.sh" every minute - if you want to run it
let's say every 3 minutes you change that to:
*/3 * * * * /root/monitoring-script.sh
2.
add startup script for 'cron' - in my case it's called "S70cron":
# ls -l /etc/init.d/S70cron
-rwxr-xr-x 1 root root 1273 Apr 23 06:53
3. startup script
#! /bin/sh
# crond Start/Stop the cron clock daemon.
# description: cron is a standard UNIX program that runs user-specified \
# programs at periodic scheduled times. vixie cron adds a \
# number of features to the basic UNIX cron, including better \
# security and more powerful configuration options.
# processname: crond
# See how we were called.
prog="crond"
start() {
echo -n $"Starting $prog: "
if [ ! -e /var/spool/cron ]; then
mkdir /var/spool/cron
mkdir /var/spool/cron/crontabs
cp /root/cron/root /var/spool/cron/crontabs/root
fi
killall crond
crond
stop() {
echo -n $"Stopping $prog: "
killall crond
restart() {
stop
start
reload() {
echo -n $"Reloading cron daemon configuration: "
killall crond -HUP
RETVAL=$?
echo
return $RETVAL
case "$1" in
start)
start
stop)
stop
restart)
restart
reload)
reload
status)
rhstatus
echo $"Usage: $0 {start|stop|reload|restart}"
exit 1
esac
Best regards !
zhangchao
Return to General discussion
