TBS 6928 signal loss
Postby Cabbanis » Fri Apr 11, 2014 1:25 am
Hello! Got a little problem with my new card. Only on some dvb-s2 channels it breaks the signal after a few secconds. But when I start DVBdream from this problematic channel, it works fine. If I change from another to this channel, signal loss. Got the latest drivers for windows. Dvbdream 2.5a
My PC:
TBS 6928
Core i5 2500k
Nvidia GTX 570
Corsair Vengeance 8GB
MSI P67A-C45
Logs.rar
(5.44 KiB) Downloaded 61 times
Cabbanis
Re: TBS 6928 signal loss
Postby steven » Fri Apr 11, 2014 6:49 pm
Hi Cabbanis
So strange your problem is, from the log file it is like that you are using DiSEqc?
and change channels are on different satellite ?
Postby Cabbanis » Tue Apr 15, 2014 8:34 pm
Yes, they're on different sattelites. I'm using diseqc 1.1 with raw commands.
Cabbanis
