How Build deb Package Driver just my drivers not all of them
Postby maysam » Tue Apr 29, 2014 12:10 pm
I try to build deb package driver for just 6925, and i cant customize to build deb package from last driver (tbs-linux-drivers_v140425.zip) for 6925
Please help me.
maysam
Re: How Build deb Package Driver just my drivers not all of
Postby updatelee » Tue Apr 29, 2014 8:04 pm
make menuconfig
Postby maysam » Wed Apr 30, 2014 4:14 pm
tank you very mutch for your reply
part of the Question is solved. but i cant build DKMS deb package from it.
maysam
Postby maysam » Sun May 04, 2014 12:55 pm
Nobody can help me
maysam
Postby updatelee » Sun May 04, 2014 9:26 pm
for a full kernel we use make deb-pkg but I never tried that on TBS's drivers. give it a go, see what happens.
Postby maysam » Sun May 11, 2014 3:02 pm
hi :)
I do but i get Error
make[4]: *** No rule to make target `/home/tbs-linux-drivers_v140425/linux-tbs-drivers-1.0.1/v4l/tbs8921ctrl.o', needed by `/home/tbs-linux-drivers_v140425/linux-tbs-drivers-1.0.1/v4l/tda18271.o'. Stop.
make[3]: *** [_module_/home/tbs-linux-drivers_v140425/linux-tbs-drivers-1.0.1/v4l] Error 2
make[3]: Leaving directory `/usr/src/linux-headers-3.13.0-24-generic'
make[2]: *** [default] Error 2
make[2]: Leaving directory `/home/tbs-linux-drivers_v140425/linux-tbs-drivers-1.0.1/v4l'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/tbs-linux-drivers_v140425/linux-tbs-drivers-1.0.1'
dh_auto_build: make -j1 returned exit code 2
make: *** [build] Error 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
maysam
Postby updatelee » Sun May 11, 2014 10:27 pm
You didnt follow the build instructions, you need to run the x86 32bit or 64bit script to assign the correct pre compiled lib's
Postby maysam » Wed May 28, 2014 5:26 pm
Dear UDL
I many try by run Script for 64bit In various states and I get Error. If you have time please help me.
maysam
Postby updatelee » Wed May 28, 2014 8:48 pm
can you post the error you get when you run the 64bit script ? as well can you post the output of uname -a ?
Postby maysam » Thu May 29, 2014 2:18 pm
Thank you.
[email protected]:/home/maysam/tbs-linux-drivers_v140425# uname -a
Linux s 3.13.0-24-generic #47-Ubuntu SMP x86_64 x86_64 x86_64 GNU/Linux
[email protected]:/home/maysam/tbs-linux-drivers_v140425# l
astra_scan-s2.conf dvb-usb-tbsqbox-id5880.fw dvb-usb-tbsqbox-id5923.fw linux-tbs-drivers.tar.bz2 README_TBS5880 README_TBS5980 README_TBSDVBC
astra_szap-s2.conf dvb-usb-tbsqbox-id5881.fw dvb-usb-tbsqbox-id5925.fw READMEs/ README_TBS5881 README_TBS62XY scan-s2.tar.bz2
dvb-fe-cx24116.fw dvb-usb-tbsqbox-id5910.fw dvb-usb-tbsqbox-id5928.fw README_TBS5220 README_TBS5921 README_TBS6921 szap-s2.tar.bz2
dvb-usb-tbsqbox-dvbc.fw dvb-usb-tbsqbox-id5920.fw dvb-usb-tbsqbox-id5980.fw README_TBS5280 README_TBS5922 README_TBS6980 v4l-cx23885-avcore-01.fw
dvb-usb-tbsqbox-id5220.fw dvb-usb-tbsqbox-id5921.fw FAQ README_TBS5281 README_TBS5922SE README_TBS6981
dvb-usb-tbsqbox-id5680.fw dvb-usb-tbsqbox-id5922.fw linux-tbs-drivers/ README_TBS5680 README_TBS5925 README_TBS8921
[email protected]:/home/maysam/tbs-linux-drivers_v140425# cd linux-tbs-drivers/
[email protected]:/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers# l
COPYING* INSTALL* linux/ Makefile* README* README.patches* v4l/
[email protected]:/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers# cd ..
[email protected]:/home/maysam/tbs-linux-drivers_v140425# mv linux-tbs-drivers linux-tbs-drivers-0.1.0
[email protected]:/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0# dh_make --createorig -l
Maintainer name : root
Email-Address : [email protected]
Date : Thu, 29 May 2014
Package Name : linux-tbs-drivers
Version : 0.1.0
License : blank
Type of Package : Library
Hit <enter> to confirm:
Done. Please edit the files in the debian/ subdirectory now. You should also
check that the linux-tbs-drivers Makefiles install into $DESTDIR and not in / .
Make sure you change the package name from linux-tbs-driversBROKEN to something
else, such as linux-tbs-drivers1 in the debian/control file.
[email protected]:/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0# ./v4l/tbs-x86_64.sh
[email protected]:/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0# dpkg-buildpackage
dpkg-buildpackage: source package linux-tbs-drivers
dpkg-buildpackage: source version 0.1.0-1
dpkg-buildpackage: source distribution unstable
dpkg-buildpackage: source changed by root <[email protected]>
dpkg-buildpackage: host architecture amd64
dpkg-source --before-build linux-tbs-drivers-0.1.0
debian/rules clean
dh clean
dh_testdir
dh_auto_clean
make[1]: Entering directory `/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0'
make -C /home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0/v4l distclean
make[2]: Entering directory `/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0/v4l'
rm -f *~ *.o *.ko .*.o.cmd .*.ko.cmd *.mod.c av7110_firm.h fdump \
config-compat.h Module.symvers Module.markers modules.order \
*.unsigned .*.ko.unsigned.cmd
make -C firmware clean
make[3]: Entering directory `/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0/v4l/firmware'
rm -f ihex2fw
rm -f vicam/firmware.fw dabusb/firmware.fw dabusb/bitstream.bin ttusb-budget/dspbootcode.bin cpia2/stv0672_vp4.bin av7110/bootcode.bin
make[3]: Leaving directory `/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0/v4l/firmware'
rm -f .version .*.o.flags .*.o.d Makefile.media \
Kconfig Kconfig.kern .config .config.cmd .myconfig \
.kconfig.dep
rm -rf .tmp_versions .tmp*.ver .tmp*.o
rm -f scripts/lxdialog scripts/kconfig
make -C firmware distclean
rm -f ihex2fw
for i in av7110/ cpia2/ dabusb/ ttusb-budget/ vicam/; do if [ -d $i ]; then rm -rf $i; fi; done
make[2]: Leaving directory `/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0/v4l'
make[1]: Leaving directory `/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0'
dh_clean
dpkg-source -b linux-tbs-drivers-0.1.0
dpkg-source: info: using source format `3.0 (quilt)'
dpkg-source: info: building linux-tbs-drivers using existing ./linux-tbs-drivers_0.1.0.orig.tar.xz
dpkg-source: info: building linux-tbs-drivers in linux-tbs-drivers_0.1.0-1.debian.tar.gz
dpkg-source: info: building linux-tbs-drivers in linux-tbs-drivers_0.1.0-1.dsc
debian/rules build
dh build
dh_testdir
dh_auto_configure
dh_auto_build
No version yet, using 3.13.0-24-generic
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 3.13.0
cd <your kernel dir>
./scripts/make_myconfig.pl
perl scripts/make_config_compat.pl /lib/modules/3.13.0-24-generic/build ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make -C firmware
CC ihex2fw
Generating vicam/firmware.fw
Generating dabusb/firmware.fw
Kernel build directory is /lib/modules/3.13.0-24-generic/build
make -C /lib/modules/3.13.0-24-generic/build SUBDIRS=/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0/v4l modules
make[3]: Entering directory `/usr/src/linux-headers-3.13.0-24-generic'
CC [M] /home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0/v4l/cx88-dvb.o
make[4]: *** No rule to make target `/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0/v4l/tbs8921ctrl.o', needed by `/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0/v4l/tda18271.o'. Stop.
make[3]: *** [_module_/home/maysam/tbs-linux-drivers_v140425/linux-tbs-drivers-0.1.0/v4l] Error 2
maysam
