How to configure oscam
Postby bzoli72 » Sat May 03, 2014 4:45 am
Hi all!
I installed Matrixtv 1.0.0.6-1.
Settigns oscam.server file in startup config.
oscam connect to remote server, but no picture on scrambled channels.
In oscam log no request from user.
Please help me, how to configure correctly XBMC -- VDR -- oscam.
Thenks: bzoli72
Sorry for my bad english
bzoli72
Re: How to configure oscam
Postby alanb2121 » Thu May 08, 2014 10:12 am
I have a similar problem. I can get TVheadend working and talking to OSCAM but not VDR.
Also VDR client in XBMC seems to work but tvheadend client in XBMC is not working
alanb2121
Postby luistobcn » Thu May 08, 2014 11:18 pm
I can not get it to work? dvb-s tvheaden and Oscam.
Please can you help me.
luistobcn
Postby mijanek » Sat May 10, 2014 6:49 pm
alanb2121 wrote:Also VDR client in XBMC seems to work but tvheadend client in XBMC is not working
Tvheadend client in xbmc is working fine. I'm using it all the time without any issue.
mijanek
Postby luistobcn » Sat May 10, 2014 9:28 pm
HI.But,tvheaded client working with dvb-s2 ?and oscam.
luistobcn
Postby mijanek » Sat May 10, 2014 9:48 pm
luistobcn wrote:HI.But,tvheaded client working with dvb-s2 ?and oscam.
This is not client who is talking to dvb-s2, but the tvheadend server listening on http://*:9981/. You have to configure it.
mijanek
Postby luistobcn » Sun May 11, 2014 2:38 am
Ah,ok thanck.
luistobcn
Postby luistobcn » Tue May 13, 2014 4:11 pm
I do not work for talk tvheaden server and oscam no generate camd.socket.
I can't do work in mode oscam,in vdr or tvheaden.
the oscam server connet.
i've been fifteen days with matrix and tbs5980.not operate these configurations.
I'm tired of wasting time.
I thought that everything was more advanced tvmatrix OS
luistobcn
Postby diabloss » Wed May 14, 2014 5:36 pm
For dvbapi + Tvheadend will need camd.socket file or an option for LD_PRELOAD=/path/to/capmt_ca.so cam_client & which sadly on this version of Matrix file sistem Tvheadend won't work.
Imo at this point best combination for matrix tv device is vdr with vdr-sc plugin + oscam as the vdr seems to be more stable for watching /zapping via xbmc live tv channels.
I highly advise if possible to provide to the end users a method to enable vdr-sc plugin support
as there are many of them that are NOT using card readers connected on to the matrix (dvbapi cannot perform while subscription card is on another machine)
but having dedicated machines for their subscriptions (raspberry pi in my case).
Regards
diabloss
Return to Install and setup
