6981 Driver install problem
Postby sctmon » Thu May 15, 2014 7:24 pm
Can anyone offer any help with installing the drivers for my new TBS 6981 dual dvb-s2 card. It is a new install of mythbuntu 14.04, kernel is 3.13.0-24 and this is the terminal output with the error.
Code: Select all
make[2]: Leaving directory `/usr/src/linux-headers-3.13.0-24-generic'
./scripts/rmmod.pl check
found 519 modules
make[1]: Leaving directory `/usr/tbs/linux-tbs-drivers/v4l'
make -C /usr/tbs/linux-tbs-drivers/v4l install
make[1]: Entering directory `/usr/tbs/linux-tbs-drivers/v4l'
Removing obsolete files from /lib/modules/3.13.0-24-generic/kernel/drivers/media/common:
Removing obsolete files from /lib/modules/3.13.0-24-generic/kernel/drivers/media/dvb/frontends:
Removing obsolete files from /lib/modules/3.13.0-24-generic/kernel/drivers/media/IR/keymaps:
Removing obsolete files from /lib/modules/3.13.0-24-generic/kernel/drivers/media/IR:
Removing obsolete files from /lib/modules/3.13.0-24-generic/kernel/drivers/media/video:
Removing obsolete files from /lib/modules/3.13.0-24-generic/kernel/drivers/media/dvb/cinergyT2:
Distro kernel with a non-standard place for modules detected.
Removing old/obsolete LUM files from /lib/modules/3.13.0-24-generic//updates/dkms:
Installing kernel modules under /lib/modules/3.13.0-24-generic/kernel/drivers/media/:
   dvb/pt1/: earth-pt1.ko install: cannot remove '/lib/modules/3.13.0-24-generic/kernel/drivers/media/dvb/pt1/earth-pt1.ko': Permission denied
strip:/lib/modules/3.13.0-24-generic/kernel/drivers/media/dvb/pt1/earth-pt1.ko: could not create temporary file to hold stripped copy: No error
make[1]: *** [media-install] Error 1
make: *** [install] Error 2
Thanks in advance!
sctmon
Re: 6981 Driver install problem
Postby sctmon » Thu May 15, 2014 10:40 pm
I managed to get the install to run without errors but the drivers don't seem to have loaded on a reboot. This is the output of dmesg | grep cx if that helps?
Code: Select all
[    3.002970] cx23885: disagrees about version of symbol ir_raw_event_handle
[    3.002974] cx23885: Unknown symbol ir_raw_event_handle (err -22)
[    3.003016] cx23885: disagrees about version of symbol tda18271_attach
[    3.003018] cx23885: Unknown symbol tda18271_attach (err -22)
[    3.003142] cx23885: disagrees about version of symbol ir_raw_event_store
[    3.003143] cx23885: Unknown symbol ir_raw_event_store (err -22)
[    3.003278] cx23885: disagrees about version of symbol rc_register_device
[    3.003279] cx23885: Unknown symbol rc_register_device (err -22)
[    3.003326] cx23885: disagrees about version of symbol rc_free_device
[    3.003327] cx23885: Unknown symbol rc_free_device (err -22)
[    3.003354] cx23885: disagrees about version of symbol rc_allocate_device
[    3.003356] cx23885: Unknown symbol rc_allocate_device (err -22)
[    3.003435] cx23885: disagrees about version of symbol rc_unregister_device
[    3.003436] cx23885: Unknown symbol rc_unregister_device (err -22)
sctmon
Postby cody » Fri May 16, 2014 12:15 am
please, read FAQ text file included with the drivers.
Postby sctmon » Fri May 16, 2014 2:15 am
Thanks, I did see the faq a while ago before I bought the card but seem to have forgotton about it. Will try it out tomorrow!
sctmon
Postby sctmon » Thu May 22, 2014 5:22 am
I was holding off replying to (hopefully) make sure I wasn't being stupid and missing something obvious this time.
I followed the FAQ and then installed the drivers as per the instructions, reboot and the dev/dvb folder is there. My mythtv backend can see the tuners but with this message:
could not get info for card /dev/dvb/adaptor0/frontend0/subtype: unknown error
When I reboot again, dev/dvb is gone. this happens every time I rebuild the drivers.
Can anyone offer any help or suggestions?
sctmon
Postby sctmon » Sun May 25, 2014 2:13 am
Just for the benefit of anyone else having problems with the TBS Linux drivers, they just dont seem to work (at least for me). I followed the instructions (and FAQ) on fresh installs of Mythbuntu and Ubuntu 14.04 and 12.04 as well as Linux mint 16 but just couldn't make it work.
What I hadn't realised until now is that open source drivers for the 6981 are included in the current kernel, I hadn't noticed because I had just been installing the os then building the drivers without checking first.
All you need to do is copy the firmware available from TBS to lib/firmware and it works.
Again, don't was your time with the 'proprietary' drivers, more grief than they are worth.
sctmon
Return to Install and setup
