issues after kernel update
Postby DARKHalf » Sun Jun 01, 2014 8:17 pm
yesterday my distro (xbmcbuntu) made a kernel update and since then I try to get the driver for my tbs6928 running.
I've downloaded tbs-linux-drivers_v140425.zip and made "make && make install". Everything was compiling and install was also successful.
but after a reboot the driver seems not to be loaded properly.
Here is some output:
Code: Select all
[email protected]:~$ dmesg | grep cx
[email protected]:~$ dmesg | grep tbs
[    3.766682] tbs6290fe: module license 'TurboSight Proprietary' taints kernel.
[email protected]:~$ uname -a
Linux ftedv-srv 3.13.0-27-generic #50-Ubuntu SMP Thu May 15 18:06:16 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
[email protected]:~$ ls -al /dev/dvb
ls: Zugriff auf /dev/dvb nicht möglich: Datei oder Verzeichnis nicht gefunden
[email protected]:~$ lsmod | grep tbs
tbs6922fe              22478  0
tbs6928fe              17785  0
tbs6991se              17882  0
tbs6290fe              50747  0
[email protected]:~$ lspci | grep Multimedia
01:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
The strange thing about this is that it seems to load the wrong module or firmware I guess, because dmesg gives output from tbs6290fe.
Oh, and yes: I did the exact steps for compiling and installing the driver. Everything was successful but I do not get the drivers loaded.
Any advice would be great as I'm getting mad.
Regards,
Florian
DARKHalf
Re: issues after kernel update
Postby SergioDanielG » Mon Jun 02, 2014 8:28 am
Hi DARKHalf.
Did you delete all media drivers from your kernel modules before install tbs-drivers?
If not, try deleting all from your /lib/modules/{your-kernel-version}/kernel/dirvers/media
and reinstall tbs drivers.
Regards.
SergioDanielG
Postby DARKHalf » Mon Jun 02, 2014 5:38 pm
Hi, yes I did. Additionally I did a complete re-setup of the whole system last night.
Even then I had no success. Even with the clean system the dvb frontend will not be created.
I have no clue what's missing since the driver will give no additional output. Is there a way to
switch v4l to verbose to see if it gives information why it does not set up the dvb frontend?
Regards,
Florian
DARKHalf
Postby DARKHalf » Mon Jun 02, 2014 5:44 pm
I thing I found something:
Code: Select all
Jun  1 20:43:14 ftedv-srv kernel: [    3.324853] saa716x_core: disagrees about version of symbol dvb_dmxdev_init
Jun  1 20:43:14 ftedv-srv kernel: [    3.324861] saa716x_core: Unknown symbol dvb_dmxdev_init (err -22)
Jun  1 20:43:14 ftedv-srv kernel: [    3.324903] saa716x_core: disagrees about version of symbol dvb_register_adapter
Jun  1 20:43:14 ftedv-srv kernel: [    3.324906] saa716x_core: Unknown symbol dvb_register_adapter (err -22)
Jun  1 20:43:14 ftedv-srv kernel: [    3.324922] saa716x_core: disagrees about version of symbol dvb_dmx_release
Jun  1 20:43:14 ftedv-srv kernel: [    3.324925] saa716x_core: Unknown symbol dvb_dmx_release (err -22)
Jun  1 20:43:14 ftedv-srv kernel: [    3.324938] saa716x_core: disagrees about version of symbol dvb_net_init
Jun  1 20:43:14 ftedv-srv kernel: [    3.324940] saa716x_core: Unknown symbol dvb_net_init (err -22)
Jun  1 20:43:14 ftedv-srv kernel: [    3.324949] saa716x_core: disagrees about version of symbol dvb_dmxdev_release
Jun  1 20:43:14 ftedv-srv kernel: [    3.324952] saa716x_core: Unknown symbol dvb_dmxdev_release (err -22)
Jun  1 20:43:14 ftedv-srv kernel: [    3.324962] saa716x_core: disagrees about version of symbol dvb_frontend_detach
Jun  1 20:43:14 ftedv-srv kernel: [    3.324965] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
Jun  1 20:43:14 ftedv-srv kernel: [    3.324970] saa716x_core: disagrees about version of symbol dvb_net_release
Jun  1 20:43:14 ftedv-srv kernel: [    3.324973] saa716x_core: Unknown symbol dvb_net_release (err -22)
Jun  1 20:43:14 ftedv-srv kernel: [    3.324980] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
Jun  1 20:43:14 ftedv-srv kernel: [    3.324982] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
Jun  1 20:43:14 ftedv-srv kernel: [    3.324990] saa716x_core: disagrees about version of symbol dvb_register_frontend
Jun  1 20:43:14 ftedv-srv kernel: [    3.324993] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
Jun  1 20:43:14 ftedv-srv kernel: [    3.325001] saa716x_core: disagrees about version of symbol dvb_unregister_adapter
Jun  1 20:43:14 ftedv-srv kernel: [    3.325004] saa716x_core: Unknown symbol dvb_unregister_adapter (err -22)
Jun  1 20:43:14 ftedv-srv kernel: [    3.325008] saa716x_core: disagrees about version of symbol dvb_dmx_init
Jun  1 20:43:14 ftedv-srv kernel: [    3.325010] saa716x_core: Unknown symbol dvb_dmx_init (err -22)
Well this seems to be the answer why it is not working. OK, this is a clean setup and compilation did work so far.
I'll have to fiddle around with the saa716x module to see if I can get it working.
DARKHalf
Postby DARKHalf » Mon Jun 02, 2014 6:02 pm
Hurray! I've fixed it! :-)
The media folder was not completely clean after my first try of deleting the files.
After I found the above error I've had a second look in the kernel's modules directory.
After deleting all files and reinstalling the driver and doing a reboot the card was initialized properly.
Thanks for the hint SergioDanielG.
DARKHalf
Postby SergioDanielG » Mon Jun 02, 2014 7:18 pm
You are welcome and thanks for solution confirmation.
Regards.
SergioDanielG
