For eumetsat new signal not stable problem(Solved)
Postby steven » Thu Jul 03, 2014 3:41 pm
Hi All
Update: Great news that we have already solved this problem, Please use our latest driver and
TBSrecorder ,TBSIPtools.
TBS6925:
http://www.tbsdtv.com/download/document/tbs6925/tbs6925-windows-driver_v1.0.1.23.zip
TBS5925:
http://www.tbsdtv.com/download/document/tbs5925/tbs5925-windows-driver_v1.0.1.11.zip
TBSIPtool for TBS6925 and TBS5925
http://www.tbsdtv.com/download/document/common/tbs-iptool_v3.0.4.0-6925&5925.zip
TBS Recorder for TBS6925 and TBS5925
http://www.tbsdtv.com/download/document ... .0.0.8.zip
and a user guide how to lock Eumetsat signal:
http://www.tbsdtv.com/download/document/common/How-to-lock-Eumetsat-VCM-signal-with-TBS-IP-tool.pdf
Any problem with this,Please email to support#tbsdtv.com . :)
Re: For eumetsat new signal not stable problem
Postby satesco » Fri Jul 04, 2014 12:39 pm
Hi steven,
Look in your pm.
Best regards
satesco
Postby dogman » Fri Jul 04, 2014 1:33 pm
If I have understood this correctly, you are saying that you will replace any 6925 card with this new card?
Is that right?
dogman
Postby crazycat » Sat Jul 05, 2014 10:08 am
steven wrote:We did found some problem with 6925 to receive Eumetsat new signal:
Maybe main problem NON STANDARD Rolloff 5% ? :) stv090x report rolloff 20% and we have bugs :)
Rolloff 5% is part of dvb-s2x extension. Look like Newtec want promote own new dvbs2x-compatible modems and setup this s2x modulation :)
But Eumetcast still provide transponder info as DVB-S2 and compatible devices with stv090x :) And users report same reports about packet losses with many devices including 5925/6925 :)
P.S. First time planned SR=30000, rolloff 20% - this fit to standard 36MHz transponder :) And stv090x receive without problems :)
Postby mikeg4cfz » Sat Jul 05, 2014 8:55 pm
Well done TBS for dealing with this problem in a positive and excellent way, looking forward to trying out new Tuner.
mikeg4cfz
Postby dogman » Sat Jul 05, 2014 9:39 pm
So what is the procedure for the exchange of cards and do we wait for a month for TBS to build up stock?
dogman
Postby satesco » Sat Jul 05, 2014 11:54 pm
steven wrote:For eumetsat new signal not stable problem
signal on 11263 H,33000,3/5-Eumetcast:
Eumetcasts with TSAnalyzer:
Eumetcast with TBS Data Service:
satesco
Postby satesco » Sun Jul 06, 2014 4:36 am
Hi steven,
I've done tests with TSAnalyzer later on 11263 H(Eumetcast)and this time stream lost packets.If you think it helps,I put a ts.file recorded on this stream-HERE
satesco
Postby steven » Mon Jul 07, 2014 9:55 am
dogman wrote:If I have understood this correctly, you are saying that you will replace any 6925 card with this new card?
Is that right?
Hi dogman
If you are the member of eumetsat,we will help you replace a new one.because for other satellite it is ok, no problem
no need to replace a new one.
kind Regards
Postby mikeg4cfz » Mon Jul 21, 2014 1:36 am
Steven, Hi, I am given to understand here in Europe that some new software has been released by Crazycat to enable TBS-6925 to receive EUMETSAT DVB-S2/VCM Transmissions on GNU/Linux systems, if correct will you be issuing software up-date for Windows XP/7/8, as full operational data transmissions start between August 4th to 8th 2014, also understand new Tuner TBS-6983 is under test in Europe with excellent results. Regards, mikeg4cfz.
mikeg4cfz
