TvHeadEnd
TvHeadEnd
Postby Jason1 » Fri Jul 11, 2014 6:51 pm
I just received my new Moi Stream Box today and began trying to set it up. I have one 90cm dish with a USALS H-H motor setup and was hoping to use the Moi Stream Box with it. Apparently the version of TvHeadEnd supplied with the stream box is version 3.5.204 and does not support USALS H-H motors. Scanning through the TvHeadEnd website and repository it seems they have added USALS motor support sometime around November 2013 and added it to the Master source code https://tvheadend.org/projects/tvheadend/repository/changes/src/input/mpegts/linuxdvb/linuxdvb_rotor.c?rev=master. I was wondering if someone could update the filesystem with the newest version of TvHeadEnd so that I can get USALS support for my setup or at least provide a step by step document as to how to package, compile and install it to my MOI Stream box. Without USALS support this device is useless to me.
Thank You
Jason
Jason1
Return to Install and setup
