XBMC does not run
XBMC does not run
Postby PG78420 » Wed Aug 27, 2014 5:00 am
Hi All,
After 3 days using the matrix, I meet different issues:
1)The sound card looks working strange with my HC amp (hdmi connected), means that the voices are in the left rear speaker and not in the central one!!!!!
2)Since yesterday , matrix doesn't run XBMC at all. When I start the matrix, the 1st screen with the message "bla bla bla ...after 3 sec xbmc will start" appears and after, nothing, black screen. I look at the boot menu and test the matrix with no issue.
As my technical bacgroung is poor, do you have an idea/solution to those 2 problems
THX in advance for your help
PG78420
Return to Install and setup
