TBS6281 on Ubuntu 14.04.1 LTS
Postby Claes » Mon Sep 15, 2014 2:42 pm
I recently bought a pair of TBS6281 DVB-T/T2 cards and I have now installed one of them in my server at home. The installation went fine, but I had to delete the contents of the "media"-folder in /lib/modules/3.13.0-34-generic/kernel/drivers/media/ at first. The problem that I have now is that I cannot tune in any DVB-T2 channels at all. If I remove the cable to my antenna and put it in my TV and scan I find the channels without any problems.
Isn't it possible to use both DVB-T and DVB-T2 at the same time?
Thanks in advance!
My setup:
Linux version:
Ubuntu 14.04.1 LTS (64bit)
Kernel 3.13.0-34-generic
TBS Drivers:
tbs-linux-drivers_v140819.zip
Information from LSDVB:
lsdvb
Version: 0.0.4
Copyright (C) Manu Abraham
SAA716x TBS (1131:7160 6281:1) on PCI Domain:0 Bus:1 Device:0 Function:0
DEVICE:0 ADAPTER:0 FRONTEND:0 (TurboSight TBS 62x1 DVBT/T2 frontend)
FE_OFDM Fmin=42MHz Fmax=1002MHz
DEVICE:0 ADAPTER:1 FRONTEND:0 (TurboSight TBS 62x1 DVBT/T2 frontend)
Information from LSPCI:
lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
00:1c.5 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 6 (rev b5)
00:1c.6 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 (rev b5)
00:1c.7 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 8 (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation H67 Express Chipset Family LPC Controller (rev 05)
00:1f.2 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family 4 port SATA IDE Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
00:1f.5 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family 2 port SATA IDE Controller (rev 05)
01:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
04:00.0 USB controller: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller
Information from DMESG:
dmesg|grep -w 'dvb\|DVB\|62x1\|6281'
[ 4.126819] input: saa716x IR (TurboSight TBS 6281) as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/rc/rc0/input6
[ 4.143790] rc0: saa716x IR (TurboSight TBS 6281) as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/rc/rc0
[ 4.144346] DVB: registering new adapter (SAA716x dvb adapter)
[ 5.714571] TurboSight TBS 62x1 Frontend:
[ 6.745652] TurboSight TBS 62x1 Frontend:
[ 6.746434] TurboSight TBS6281 DVB-T2 card MAC=ff:ff:ff:ff:ff:ff
[ 6.746436] DVB: registering adapter 0 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
[ 6.746597] DVB: registering new adapter (SAA716x dvb adapter)
[ 8.345174] TurboSight TBS 62x1 Frontend:
[ 9.520350] TurboSight TBS 62x1 Frontend:
[ 9.521131] TurboSight TBS6281 DVB-T2 card MAC=ff:ff:ff:ff:ff:ff
[ 9.521133] DVB: registering adapter 1 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
[22884.757045] DVB: adapter 0 frontend 0 frequency 570000 out of range (42000000..1002000000)
Claes
Re: TBS6281 on Ubuntu 14.04.1 LTS
Postby crazycat » Mon Sep 15, 2014 11:09 pm
look like need set freq in Hz :)
Postby Claes » Tue Sep 16, 2014 1:29 am
Thanks, but I think that is the result of an old scan. I will redo the test ASAP and return with results :)
Thanks so far!
Claes
Postby xakutin » Thu Oct 30, 2014 5:36 am
I have the same problem in openSUSE 13.1
It doesn't tune and besides it has not scanned all the channels.
This is my setup:
Linux version:
openSUSE 13.1
Linux 3.17.1-2.g5c4d099-desktop #1 SMP PREEMPT Sat Oct 18 23:36:23 UTC 2014 (5c4d099) x86_64 x86_64 x86_64 GNU/Linux
TBS Drivers:
LSDVB:
LSPCI:
00:00.0 Host bridge: Intel Corporation ValleyView SSA-CUnit (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation ValleyView Gen7 (rev 0c)
00:13.0 SATA controller: Intel Corporation ValleyView 6-Port SATA AHCI Controller (rev 0c)
00:14.0 USB controller: Intel Corporation ValleyView USB xHCI Host Controller (rev 0c)
00:1a.0 Encryption controller: Intel Corporation ValleyView SEC (rev 0c)
00:1b.0 Audio device: Intel Corporation ValleyView High Definition Audio Controller (rev 0c)
00:1c.0 PCI bridge: Intel Corporation ValleyView PCI Express Root Port (rev 0c)
00:1c.1 PCI bridge: Intel Corporation ValleyView PCI Express Root Port (rev 0c)
00:1c.2 PCI bridge: Intel Corporation ValleyView PCI Express Root Port (rev 0c)
00:1c.3 PCI bridge: Intel Corporation ValleyView PCI Express Root Port (rev 0c)
00:1f.0 ISA bridge: Intel Corporation ValleyView Power Control Unit (rev 0c)
00:1f.3 SMBus: Intel Corporation ValleyView SMBus Controller (rev 0c)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 11)
01:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 03)
Subsystem: Device [6281:0001]
Region 0: Memory at d0700000 (64-bit, non-prefetchable) [size=1M]
Address: 0000000000000000 Data: 0000
Kernel modules: saa716x_tbs_dvb
DMESG:
[ 9.794023] input: saa716x IR (TurboSight TBS 6281) as /devices/pci0000:00/0000:00:1c.0/0000:01:00.0/rc/rc0/input14
[ 9.794167] rc0: saa716x IR (TurboSight TBS 6281) as /devices/pci0000:00/0000:00:1c.0/0000:01:00.0/rc/rc0
[ 9.794565] DVB: registering new adapter (SAA716x dvb adapter)
[ 11.636717] TurboSight TBS 62x1 Frontend:
[ 12.564085] TurboSight TBS 62x1 Frontend:
[ 12.564872] TurboSight TBS6281 DVB-T2 card MAC=ff:ff:ff:ff:ff:ff
[ 12.564878] DVB: registering adapter 0 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
[ 12.565285] DVB: registering new adapter (SAA716x dvb adapter)
[ 13.914564] TurboSight TBS 62x1 Frontend:
[ 14.949096] TurboSight TBS 62x1 Frontend:
[ 14.949887] TurboSight TBS6281 DVB-T2 card MAC=ff:ff:ff:ff:ff:ff
[ 14.949896] DVB: registering adapter 1 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
Errors in Tvheadend
2014-10-29T22:30:44.535345+01:00 barebone tvheadend[1896]: tsdemux: /dev/dvb/adapter0/frontend0 - SI packet had errors
2014-10-29T22:30:44.535617+01:00 barebone tvheadend[1896]: psi: pid 0012 cc error 11 != 3
2014-10-29T22:30:44.561591+01:00 barebone tvheadend[1896]: tsdemux: /dev/dvb/adapter0/frontend0 - SI packet had errors
2014-10-29T22:30:44.561891+01:00 barebone tvheadend[1896]: psi: pid 0012 cc error 4 != 6
2014-10-29T22:30:44.562068+01:00 barebone tvheadend[1896]: psi: pid 0000 cc error 6 != 9
2014-10-29T22:30:44.588163+01:00 barebone tvheadend[1896]: tsdemux: /dev/dvb/adapter0/frontend0 - SI packet had errors
2014-10-29T22:30:44.589262+01:00 barebone tvheadend[1896]: message repeated 5 times: [ tsdemux: /dev/dvb/adapter0/frontend0 - SI packet had errors]
2014-10-29T22:30:44.589428+01:00 barebone tvheadend[1896]: psi: pid 0001 cc error 6 != 9
2014-10-29T22:30:44.589594+01:00 barebone tvheadend[1896]: cat: invalid table length 5 min 7
2014-10-29T22:30:44.589774+01:00 barebone tvheadend[1896]: psi: pid 0012 cc error 8 != 10
2014-10-29T22:30:44.614270+01:00 barebone tvheadend[1896]: tsdemux: /dev/dvb/adapter0/frontend0 - SI packet had errors
2014-10-29T22:30:44.614533+01:00 barebone tvheadend[1896]: psi: pid 0012 cc error 11 != 13
2014-10-29T22:30:44.614738+01:00 barebone tvheadend[1896]: psi: pid 07D0 cc error 10 != 3
2014-10-29T22:30:44.633774+01:00 barebone tvheadend[1896]: tsdemux: /dev/dvb/adapter1/frontend0 - SI packet had errors
2014-10-29T22:30:44.634038+01:00 barebone tvheadend[1896]: tsdemux: /dev/dvb/adapter1/frontend0 - SI packet had errors
2014-10-29T22:30:44.634216+01:00 barebone tvheadend[1896]: psi: pid 0012 cc error 0 != 3
xakutin
Re: TBS6281 doesn't tune well
Postby xakutin » Fri Oct 31, 2014 5:32 am
Today I have downgrade the linux kernel to:
Linux 3.11.10-17-desktop #1 SMP PREEMPT Mon Jun 16 15:28:13 UTC 2014 (fba7c1f) x86_64 x86_64 x86_64 GNU/Linux
But it is still not working.
This is the result of a scan /usr/share/dvb/dvb-t/es-Madrid > .tzap/channels.conf
[01a5]:746000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:421
[01a6]:746000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:422
[01a7]:746000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:423
[01a9]:746000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:425
[274c]:746000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:10060
[2754]:746000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:10068
[0212]:770000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:530
[0213]:770000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:531
[0214]:770000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:1001:1003:532
[0215]:770000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:533
[0216]:770000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:301:0:534
[0217]:770000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:535
[0218]:770000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:2031:536
[0219]:770000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:537
antena3 HD:778000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:101:103:149
antena3:778000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:201:203:150
laSexta HD:778000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:301:303:151
laSexta:778000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:401:403:152
neox:778000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:153
nova:778000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:154
[01a5]:810000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:421
[01a6]:810000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:422
[01a7]:810000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:311:312:423
[01a9]:810000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:425
[274c]:810000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:1001:0:10060
[2754]:810000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:10068
DATA TEST A 66:834000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_1_2:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE:1002:1003:1
DATA TEST B 66:834000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_1_2:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE:2002:2003:2
DATA TEST C 66:834000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_1_2:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE:3002:3003:3
DATA TEST D 66:834000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_1_2:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE:4002:4003:4
DATA TEST E 66:834000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_1_2:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE:5002:5003:5
VAUGHAN TV 66:834000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_1_2:QAM_16:TRANSMISSION_MODE_2K:GUARD_INTERVAL_1_32:HIERARCHY_NONE:6002:6003:6
[0154]:842000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:340
[0155]:842000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:1001:1003:341
[0159]:842000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:1601:345
[015a]:842000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:346
[015b]:842000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:1801:347
[0421]:842000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:1057
[0422]:842000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:1058
[0424]:842000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:163:92:1060
Telecinco:850000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:203:303:180
FDF:850000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:201:301:181
Energy:850000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:202:302:182
:850000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:1501:1502:301
PARAMOUNT CHANNEL¡CAMBIA DE DIAL!:850000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:307
[008c]:858000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:140
[008d]:858000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:501:503:141
[008e]:858000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:1001:1003:142
[0105]:858000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:1101:1103:261
[010d]:858000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:269
[010f]:858000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:271
[0111]:858000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:1966:273
[0113]:858000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_2_3:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:0:0:275
As you can see it doesn't return the name of various channels.
If I tune and save the stream:
tzap -r -x -c .tzap/channels.conf "Telecinco"
dvbstream 203 303 -o > /store/test.mpeg
The video is corrupted.
The antenna is ok (I try the same wire with the TV).
I don't know if it's a hardware(I bought it at buydvb.net, the worst seller I have ever met) or driver problem.
xakutin
Postby xakutin » Fri Oct 31, 2014 6:27 am
I realize there is a new driver version v141019.
I have tested it with the same result (kernel 3.17.1-3.gd944251-desktop).
It doesn't scan well and the resulting video of dvbstream is corrupted.
xakutin
Postby steven » Fri Oct 31, 2014 5:38 pm
xakutin wrote:I realize there is a new driver version v141019.
Hi xakutin
Can you send your detail issue to our linux support euro_support#tbsdtv.com,we will reply you
as soon as possible. :)
Postby Claes » Tue Dec 02, 2014 8:37 pm
The reply is a bit late. But I tried once again today and while I did that I also took the time to upgrade the drivers. Still the same result. The DVBT-2 mux is at 570000, but nothing.
When I use s_scan etc I cannot find ANY DVB-T2 channels but if I plug the same antennacable to a external DVB-T2 box is works directly. Here is my w_scan result.
w_scan-20140727# ./w_scan -cSE -C UTF-8 -R 0 -O 1 -a 0
w_scan version 20140727 (compiled for DVB API 5.10)
using settings for SWEDEN
DVB aerial
DVB-T Europe
scan type TERRESTRIAL, channellist 4
output format vdr-2.0
output charset 'UTF-8'
Using DVB API 5.3
frontend 'TurboSight TBS 62x1 DVBT/T2 frontend' supports
INVERSION_AUTO
QAM_AUTO
TRANSMISSION_MODE_AUTO
GUARD_INTERVAL_AUTO
HIERARCHY_AUTO
FEC_AUTO
FREQ (42.00MHz ... 1002.00MHz)
Scanning DVB-T...
Scanning 7MHz frequencies...
177500: (time: 00:00.000)
184500: (time: 00:03.020)
191500: (time: 00:06.040)
198500: (time: 00:09.036)
205500: (time: 00:12.032)
212500: (time: 00:15.028)
219500: (time: 00:18.048)
226500: (time: 00:21.068)
Scanning 8MHz frequencies...
474000: (time: 00:24.088)
482000: (time: 00:27.084)
490000: (time: 00:30.104)
498000: (time: 00:33.100)
506000: (time: 00:36.120)
514000: (time: 00:39.116)
522000: (time: 00:42.136) signal ok: QAM_AUTO f = 522000 kHz I999B8C999D999T999G999Y999 (0:0:0)
QAM_AUTO f = 522000 kHz I999B8C999D999T999G999Y999 (0:0:0) : updating transport_stream_id: -> (0:0:1022)
QAM_AUTO f = 522000 kHz I999B8C999D999T999G999Y999 (0:0:1022) : updating network_id -> (0:12710:1022)
QAM_AUTO f = 522000 kHz I999B8C999D999T999G999Y999 (0:12710:1022) : updating original_network_id -> (8945:12710:1022)
updating transponder:
(QAM_AUTO f = 522000 kHz I999B8C999D999T999G999Y999 (8945:12710:1022)) 0x0000
to (QAM_64 f = 522000 kHz I999B8C23D0T8G8Y0 (8945:12710:1022)) 0x405A
530000: (time: 00:48.348)
538000: (time: 00:51.368)
546000: (time: 00:54.388) signal ok: QAM_AUTO f = 546000 kHz I999B8C999D999T999G999Y999 (0:0:0)
QAM_AUTO f = 546000 kHz I999B8C999D999T999G999Y999 (0:0:0) : updating transport_stream_id: -> (0:0:1021)
QAM_AUTO f = 546000 kHz I999B8C999D999T999G999Y999 (0:0:1021) : updating network_id -> (0:12711:1021)
QAM_AUTO f = 546000 kHz I999B8C999D999T999G999Y999 (0:12711:1021) : updating original_network_id -> (8945:12711:1021)
(QAM_AUTO f = 546000 kHz I999B8C999D999T999G999Y999 (8945:12711:1021)) 0x0000
to (QAM_64 f = 546000 kHz I999B8C23D0T8G8Y0 (8945:12711:1021)) 0x405A
554000: (time: 01:00.968)
562000: (time: 01:03.988)
570000: (time: 01:07.008)
578000: (time: 01:10.004)
586000: (time: 01:13.000)
594000: (time: 01:16.020)
602000: (time: 01:19.016)
610000: (time: 01:22.036)
618000: (time: 01:25.056)
626000: (time: 01:28.076) signal ok: QAM_AUTO f = 626000 kHz I999B8C999D999T999G999Y999 (0:0:0)
QAM_AUTO f = 626000 kHz I999B8C999D999T999G999Y999 (0:0:0) : updating transport_stream_id: -> (0:0:1111)
QAM_AUTO f = 626000 kHz I999B8C999D999T999G999Y999 (0:0:1111) : updating network_id -> (0:12684:1111)
QAM_AUTO f = 626000 kHz I999B8C999D999T999G999Y999 (0:12684:1111) : updating original_network_id -> (8945:12684:1111)
(QAM_AUTO f = 626000 kHz I999B8C999D999T999G999Y999 (8945:12684:1111)) 0x0000
to (QAM_64 f = 626000 kHz I999B8C23D0T8G8Y0 (8945:12684:1111)) 0x405A
634000: (time: 01:33.368)
642000: (time: 01:36.388)
650000: (time: 01:39.408) signal ok: QAM_AUTO f = 650000 kHz I999B8C999D999T999G999Y999 (0:0:0)
Info: no data from PAT after 2 seconds
deleting (QAM_AUTO f = 650000 kHz I999B8C999D999T999G999Y999 (0:0:0))
658000: (time: 01:43.244)
666000: (time: 01:46.264)
674000: (time: 01:49.260) signal ok: QAM_AUTO f = 674000 kHz I999B8C999D999T999G999Y999 (0:0:0)
QAM_AUTO f = 674000 kHz I999B8C999D999T999G999Y999 (0:0:0) : updating transport_stream_id: -> (0:0:1110)
QAM_AUTO f = 674000 kHz I999B8C999D999T999G999Y999 (0:0:1110) : updating network_id -> (0:12593:1110)
QAM_AUTO f = 674000 kHz I999B8C999D999T999G999Y999 (0:12593:1110) : updating original_network_id -> (8945:12593:1110)
(QAM_AUTO f = 674000 kHz I999B8C999D999T999G999Y999 (8945:12593:1110)) 0x0000
to (QAM_64 f = 674000 kHz I999B8C23D0T8G8Y0 (8945:12593:1110)) 0x405A
682000: (time: 01:54.336)
690000: (time: 01:57.356)
698000: (time: 02:00.376)
706000: (time: 02:03.372)
714000: (time: 02:06.392)
722000: (time: 02:09.412)
730000: (time: 02:12.432)
738000: (time: 02:15.452)
746000: (time: 02:18.472)
754000: (time: 02:21.492)
762000: (time: 02:24.512)
770000: (time: 02:27.532)
778000: (time: 02:30.552)
786000: (time: 02:33.572)
794000: (time: 02:36.592)
802000: (time: 02:39.612)
810000: (time: 02:42.608)
818000: (time: 02:45.628)
826000: (time: 02:48.648)
834000: (time: 02:51.668)
842000: (time: 02:54.688)
850000: (time: 02:57.708)
858000: (time: 03:00.728)
tune to: QAM_64 f = 522000 kHz I999B8C23D0T8G8Y0 (8945:12710:1022) (time: 03:03.748)
service = TV6 (Viasat Broadcasting UK)
service = TV4 Film (TV4 AB)
service = Kanal 11 (SBS Broadcasting Networks Ltd)
service = CNN (Turner Broadcasting)
service = TV4 Fakta (TV4 AB)
service = TV4 Göteborg (TV4 AB)
service = Sjuan Göteborg (TV4 AB)
service = Boxer Navigator (Boxer TV Access AB)
tune to: QAM_64 f = 546000 kHz I999B8C23D0T8G8Y0 (8945:12711:1021) (time: 03:20.252)
service = Barnkanalen/SVT24 (Sveriges Television)
service = Kunskapskanalen (Sveriges Television)
service = SVT1 Tal Txt (Sveriges Television)
service = SVT2 Tal Txt (Sveriges Television)
service = SVT2 Väst (Sveriges Television)
service = SVT2 Halland (Sveriges Television)
service = SVT1 Väst (Sveriges Television)
service = SVT1 Halland (Sveriges Television)
tune to: QAM_64 f = 626000 kHz I999B8C23D0T8G8Y0 (8945:12684:1111) (time: 03:37.260)
service = Comedy Central (MTV Networks AB)
service = Kanal 9 (SBS Broadcasting Networks Ltd)
service = Eurosport (Eurosport Société)
service = Discovery Channel (Discovery Communications)
service = MTV (MTV Networks Europe)
service = Nickelodeon (MTV Europe)
service = TLC (Discovery Communications)
service = TV10 (Viasat Broadcasting UK)
service = Horse1 (Hästkanalen AB)
service = Al Jazeera (Al Jazerra Media Network)
service = Eurosport 2 (Eurosport Société)
service = History (AENT UK)
service = SMiT (Boxer CI+ CAM)
service = Humax (Humax)
service = CI + CAM (Neotion)
tune to: QAM_64 f = 674000 kHz I999B8C23D0T8G8Y0 (8945:12593:1110) (time: 03:54.248)
service = VH1 (MTV Networks Europe)
service = C More Sport/SF-Kanalen (C More Entertainment AB)
service = C More First (C More Entertainment AB)
service = TV8 (Viasat AB)
service = Disney Channel (Disney)
service = TV3 GÖTEBORG (Viasat AB)
service = Kanal 5 Göteborg (SBS Broadcasting Networks Ltd)
service = SAGEM_DOWNLOAD (Boxer TV Access AB)
service = THOMSON download (Boxer TV Access AB)
service = Pace DiT8030/13 (Pace)
(time: 04:11.248) dumping lists (44 services)
Claes
Postby BeMax » Wed Dec 31, 2014 12:13 am
Hello
It seems that we have exactly the same problem but I'm using the TBS6285 Quad card.
viewtopic.php?f=153&t=9275
Can't lock on 570 MHz (Brudaremossen) using T2 mode. Also have LTS 14.04. Have you find any solution ? I have tested many things:
1) Attenuators in front of the card if there is an "overload", Doesn't help...
2) Used an spectrum analyzer to check any interfering signal from motherboard etc, didn't find any...
My old TBS6284 works perfekt on 570 MHz and my PCTV290e as well.
EDIT:
Connected my USB TBS5881 and it works perfect on 570 MHz (T2)...
Is the the hardware or software ? I think we need help from TBS support !!! Otherwise I will return my 6285.
546000: (time: 01:18.036) signal ok: QAM_AUTO f = 546000 kHz I999B8C999D999T999G999Y999 (0:0:0)
QAM_AUTO f = 490000 kHz I999B8C999D999T999G999Y999 (0:0:1021) : updating network_id -> (0:12711:1021)
QAM_AUTO f = 490000 kHz I999B8C999D999T999G999Y999 (0:12711:1021) : updating original_network_id -> (8945:12711:1021)
(QAM_64 f = 474000 kHz I999B8C34D0T8G4Y0 (8945:12726:1021)) 0x405A
to (QAM_64 f = 474000 kHz I999B8C23D0T8G8Y0 (8945:12711:1021)) 0x405A
554000: (time: 01:22.320) signal ok: QAM_AUTO f = 554000 kHz I999B8C999D999T999G999Y999 (0:0:0)
deleting (QAM_AUTO f = 554000 kHz I999B8C999D999T999G999Y999 (0:0:0))
562000: (time: 01:28.264)
570000: (time: 01:35.156)
578000: (time: 01:41.248)
586000: (time: 01:43.272)
594000: (time: 01:46.244)
602000: (time: 01:49.264)
610000: (time: 01:52.284) signal ok: QAM_AUTO f = 610000 kHz I999B8C999D999T999G999Y999 (0:0:0)
QAM_AUTO f = 610000 kHz I999B8C999D999T999G999Y999 (0:0:0) : updating transport_stream_id: -> (0:0:1110)
QAM_AUTO f = 610000 kHz I999B8C999D999T999G999Y999 (0:0:1110) : updating network_id -> (0:12595:1110)
QAM_AUTO f = 610000 kHz I999B8C999D999T999G999Y999 (0:12595:1110) : updating original_network_id -> (8945:12595:1110)
618000: (time: 01:55.324)
BeMax
Postby Claes » Thu Jan 29, 2015 11:10 pm
I have today got contact with the support. I will update this thread when or if the T2 HDTV starts to function on my 6281-card.
Claes
