Plex on MatrixTV
Plex on MatrixTV
Postby Kohai » Thu Oct 09, 2014 12:30 am
Hi everybody
I'm wondering if it is possible to install Plex on the TBS Mini PC using Matrix TV and use the TBS as a "Plex server", if's not used as the xbmc?
Thanks for your help
Cheers
Kohai
Re: Plex on MatrixTV
Postby franky384 » Fri Oct 10, 2014 9:14 pm
Look here for more information, it should be possible if you get Arch Linux arm running on the TBS Mini PC.
#Plex Media Server Build Instructions
pacman -Sy svn
mkdir -p ~/build
cd ~/build
svn checkout https://github.com/archlinuxarm/PKGBUIL ... ediaserver
cd plexmediaserver
makepkg -Acs --asroot
#Configure @ http://alarm:32400/manage
http://www.solid-run.com/community/topic66-10.html
franky384
Postby Kohai » Sat Oct 18, 2014 1:35 am
HI Franky
Thanks for your answer! I tried to understand it somehow yet as a complete newbie I cannot really follow you...
Is there any chance to explain it more detailed..? :)
Cheers
Kohai
Postby franky384 » Sat Oct 18, 2014 6:59 am
What version are you running on your matrix? Can you login via ssh from your computer, then you can try this:
login from your computer via: ssh root@your Matrix IP-Adress
in the console type:
mkdir plex
cd plex
wget http://downloads.plex.tv/plex-media-server/0.9.11.1.678-c48ffd2/plex.tgz
tar -xvzf plex.tgz
cd Application
start.sh
if you're lucky the plexmediaserver will start.
I tried it on the Openelec build but it doesn't work. But in the SolidRun Forum someone postet it works with the 3.0.35 Kernel.
So it is possibly running on the ubuntu 12.04 or the matrixtv 1.0.10 builds.
Look here: http://www.solid-run.com/community/topic544.html#p3567
franky384
Postby Kohai » Sat Oct 18, 2014 8:20 pm
Thanks for the help! I am running the current version off matrixtv (1.0.0.9-V21)
I will give it a try an let you know
Kohai
Postby Kohai » Sat Oct 18, 2014 9:16 pm
Hi Franky
I tried it out and it worked all fine until the last step...
start.sh
"command not found"
Where can I found the Matrix Version 1.0.10?
Thanks!
Kohai
Postby vpeter » Sat Oct 18, 2014 9:23 pm
Kohai wrote:Where can I found the Matrix Version 1.0.10?
Code: Select all
http://sourceforge.net/projects/matrixtv/files/Release/MatrixTV/
Kohai wrote:start.sh
"command not found"
I think you must run
Code: Select all
./start.sh
vpeter
Postby Kohai » Sat Oct 18, 2014 10:41 pm
Thanks guys for helping me out. I tried the other command and received the following:
.[i]/start.sh: line 3: readlink: command not found
BusyBox v1.22.0 (2014-07-17 09:12:29 CST) multi-call binary.
Usage: dirname FILENAME
Strip non-directory suffix from FILENAME
./start.sh: line 11: ./Plex Media Server: No such file or directory
[/i]
I will try it later with the new version but if someone can help with the current one, I appreciate :)
Kohai
Postby vpeter » Sat Oct 18, 2014 10:51 pm
Kohai wrote:I will try it later with the new version but if someone can help with the current one, I appreciate :)
New version will not help you.
Open file start.sh and replace line
Code: Select all
SCRIPT=$(readlink -f $0)
with
Code: Select all
SCRIPT=/root/plex/Application
vpeter
Postby Kohai » Sun Oct 19, 2014 7:46 am
I changed the
to
but still receiving this error
[./start.sh: line 11: ./Plex Media Server: No such file or directory]
is there something else I could do?
Kohai
Return to Development
