problem moi pro and tbs6984
Postby BelZeBu » Fri Nov 07, 2014 9:25 pm
hi, I got the pro moi this morning. I installed the tuner that took you a long time ago and never used, new tbs6984. Is not recognized by moi pro. What do I do?
BelZeBu
Re: problem moi pro and tbs6984
Postby diabloss » Sat Nov 08, 2014 12:18 am
Flash with the latest version firmware.
Make sure you use the correct uimage file
diabloss
Postby BelZeBu » Sat Nov 08, 2014 12:53 am
Copyright © 2006-2014
TBS Technologies
All Rights Reserved.
Version 1.0.0.1
already installed, but the problem remains. I wanted to test the tuner on another pc and it works.
BelZeBu
Postby BelZeBu » Sat Nov 08, 2014 2:49 am
I downloaded the firmware again. Reinstalled for the second time. The tuner is still not recognized. Again, the tuner installed in another computer works fine
BelZeBu
Postby BelZeBu » Sat Nov 08, 2014 2:54 am
I did another test. Do not I measure no voltage at the connector Tuner 0:00 volts. I think the pro moi was sent not working
BelZeBu
Postby BelZeBu » Sat Nov 08, 2014 7:22 pm
what do I do?
BelZeBu
Postby BelZeBu » Mon Nov 10, 2014 2:00 am
It does not work, since joining never worked. Please help me and know what to do via email and forums, but the admins are silent. What should I do with this pro moi new and never worked? You can get remote support?
BelZeBu
Postby diabloss » Mon Nov 10, 2014 10:54 pm
your card have power connector , did you connected that power connector?
did you rename the DVB-C uimage file from \Profiles\MX6Q Linux Update\OS Firmware\files\ ???
if you flashed incorrectly your MOI is normal it won't detect your card.
so basically when you unpack your firmware files you should look in this path \Profiles\MX6Q Linux Update\OS Firmware\files\
there should be a file which have in the name DVB-C ... rename it to uimage overwrite if ask and then flash your moi pro
That file contain drivers and kernel for satelitte and cable cards.
diabloss
Postby BelZeBu » Sat Nov 15, 2014 10:28 am
The connection is done right. Food is ok. I downloaded the firmware as it was, I did not edited or renamed anything because the tuner is DVB-S
BelZeBu
Postby diabloss » Mon Nov 24, 2014 11:04 pm
Greetings
You have tried the USB memory stick method?
There are two methods of software update , one with the flashing tool and the second with the usb stick.
In order to make your cards visible in the console before you flash firmware you need to rename certain file
DiD you rename the DVB-C uimage file from \Profiles\MX6Q Linux Update\OS Firmware\files\ ???
there should be a file which have in the name DVB-C uimage ... rename it to uimage simple overwrite if ask and then flash your moi pro.
in that path ( \Profiles\MX6Q Linux Update\OS Firmware\files\) you should have 2 files named uImage_fsl_dvbt or uImage_fsl_dvbc .. .
One of them is for terestrial + satelite second is cable + satelite. rename one to uimage and overwrite file if ask and then use the MFG tool to flash your MOI Pro.
Make sure the button from behind is in burn position when you flash or else nothing will happen.
diabloss
Return to MOI Pro
