Error in installing TBS6985 driver on Linux
Postby cwjahng » Thu Nov 20, 2014 1:13 pm
Hi, my name is Charlie.
I bought a TBS6985 DVB-S2 card and tried to install its driver on a linux PC(CentOS 6.5). But I met a strange error during installation like this:
[root@SAT-CENTOS linux-tbs-drivers]# uname -a
Linux SAT-CENTOS 2.6.32-504.1.3.el6.x86_64 #1 SMP Tue Nov 11 17:57:25 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
[root@SAT-CENTOS linux-tbs-drivers]# ./v4l/tbs-x86_64.sh
[root@SAT-CENTOS linux-tbs-drivers]# make && make install
make -C /home/admin/TBS/linux-tbs-drivers/v4l
make[1]: Entering directory `/home/admin/TBS/linux-tbs-drivers/v4l'
No version yet, using 2.6.32-504.1.3.el6.x86_64
make[1]: Leaving directory `/home/admin/TBS/linux-tbs-drivers/v4l'
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 2.6.32
File not found: /lib/modules/2.6.32-504.1.3.el6.x86_64/build/.config at ./scripts/make_kconfig.pl line 33, <IN> line 4.
make[1]: *** No rule to make target `.myconfig', needed by `config-compat.h'. Stop.
make: *** [all] Error 2
Can anybody help me?
I could not find the similar topic in the previous forum. May I miss something?
Regards,
Charlie
cwjahng
Re: Error in installing TBS6985 driver on Linux
Postby bob » Fri Nov 21, 2014 11:27 am
bob
Postby cwjahng » Fri Nov 21, 2014 12:01 pm
No. It is useless. It looks different case.
The important error message in my case was:
but the error message in the proposed posting was different from me:
/usr/src/tbsdrivers/linux-tbs-drivers/v4l/compat.h:26: error: conflicting types for 'find_next_zero_bit'
include/linux/bitops.h:232: note: previous declaration of 'find_next_zero_bit' was here
/usr/src/tbsdrivers/linux-tbs-drivers/v4l/compat.h:32: error: conflicting types for 'find_next_bit'
include/linux/bitops.h:222: note: previous declaration of 'find_next_bit' was here.
Actually, although I followed the advice from the posting by commenting some lines of compat.h, I got the same error messages:
Please help me again~
Regards,
Charlie
cwjahng
Postby updatelee » Fri Nov 21, 2014 9:00 pm
look in /boot for your current config and copy it to that folder. Honestly though Id be surprised to see it compile. 2.6.32 is quite old (almost 5 years), might be time to upgrade your kernel.
Postby cwjahng » Fri Nov 21, 2014 9:52 pm
Hi Updatelee,
Thank you for your professional advise.
I tried it as your advise such that I copy /boot config files to /v4l drive and "make" again but got the same results.
I'm a novice for linux so I don't know how old the kernel version is since I just installed "CentOS v6.6" recently. If you say the kernel is so old, I don't know how to do.
Regards,
Charlie.
cwjahng
Postby updatelee » Sat Nov 22, 2014 12:54 am
Centos 7 is the current release
Postby cwjahng » Tue Nov 25, 2014 4:42 pm
Thank you for bob, updatelee and other people who cared this issue.
I tried deeply for days and gave up today.
It looks like a subtle mismatch between version of kernels, subtle relationships of "links", and current update status of some modules. Using the recent version of CenOS 7 was not helpful too. I tried several ways which could be found from google but finally failed.
A very strange thing is, that I tested on an older PC with CentOS 6.5 where I didn't know what history of update it had, and successfully installed TBS6985 driver on it. The symptom was different from mine, and it was the same to what bob posted first, so after I commented on some lines of the file 'compat.h' I could succeed make and make install.
I has been fighting on seeking differences between my CentOS PC and the older CentOS PC. There were some differences but I could not find out why I failed installation on a PC and why I succeeded it on another.
Too many days were wasted so I give up since I'm still only a novice on linux. I will go to Ubuntu or other linux out of CentOS.
Thank you very much~
Charlie.
cwjahng
Postby cwjahng » Wed Nov 26, 2014 3:39 pm
I installed TBS6985 driver on Ubuntu successfully without any errors. I checked the device through tvheadend administration pages too. TBS6985 is working well.
I still have question why CentOS is not friendly with it.
Regards,
Charlie
cwjahng
