MOIPro Firmware V1.0.0.5 is released.
Postby steven » Mon Jan 19, 2015 2:39 pm
Hi All
Update Please use V1.0.0.5 version which fixed web page dvblast can not stream issue.
News:
1.Web service add login and reboot control (the default user name is root and password is root )
2.Fix low symbol rate can not be scaned issue
3.Update online Web update more easy to use
4.Fix some small bugs
With this new version we provide a web update package ,Here is a read me method there which will tell you how to update
through web page(Make sure that your MOIPro firmware is V1.0.0.3 or newer)
http://www.tbsdtv.com/download/document/tbs2911/How-to-upgrade-MOI-Pro-V1.3.pdf
Here is the download link:
For USB update(Please use FAT32 USB flash disk):
http://sourceforge.net/projects/moipro/files/Release/MOIPro_AutoUpdate_V1.0.0.5.zip/download
For PC update:
http://sourceforge.net/projects/moipro/files/Release/MOIPro_V1.0.0.5.zip/download
For Web page update;
DVBS+DVBC kernel support package
http://sourceforge.net/projects/moipro/files/Release/MOIPro-web-update-c-V1.0.0.5.zip/download
DVBS+DVBT kernel support package
http://sourceforge.net/projects/moipro/files/Release/MOIPro-web-update-t-V1.0.0.5.zip/download
Any question with this ,just send reply here,we will answer it later :)
Re: MOIPro Firmware V1.0.0.4 is released.
Postby developer » Tue Jan 20, 2015 3:09 am
Any update to type wifi password?
Would be better to show a page in which active streams are shown or atleast the ones which can be accessed in next release.
developer
Postby steven » Wed Jan 21, 2015 3:35 pm
developer wrote:Any update to type wifi password?
In the webpage you can input the wifi password. :)
Postby riedelralf » Wed Jan 21, 2015 3:37 pm
Nice, just installed...
checked Dvblast settings and it doesn't start streaming.
All 8 Tuner locked, services can be chosen, udp as well, than save and start -> Nothing happens.
Another recommendation: RTP is a protocoll which is on top of UDP. So if no UDP was chosen, than RTP is streamed but not displayed?
Sounds not very logically.
Another issue: The tuner and board numbering is not like printed on the pcbs:
Adapter 0 is th bottom pcb
Adapter 1 is the top pcb.
Than LNBA= frontend 0
LNBD= frontend 3
If already have a oscam server running in the network, would it be possible to get a simple client for it like newcamd/mgcamd compiled?
riedelralf
Postby steven » Thu Jan 22, 2015 10:36 am
riedelralf wrote:Nice, just installed...
LNBD= frontend 3
Hi riedelralf
Thanks so much for this feedback, we will check this as soon as possible.
Postby steven » Thu Jan 22, 2015 11:49 am
LNBD= frontend 3
Please use web update way to update V1.0.0.5 which fixed this problem.
http://sourceforge.net/projects/moipro/ ... p/download
Sorry for the inconvienence.
Re: MOIPro Firmware V1.0.0.5 is released.
Postby y12345678 » Thu Jan 22, 2015 1:10 pm
do you have to reset the TVheadend after update?
If yes, what's the best way to make a backup for tvheadend?
y12345678
Postby steven » Thu Jan 22, 2015 5:31 pm
y12345678 wrote:do you have to reset the TVheadend after update?
The tvheadend config file is store in
/root/.hts
You can manual backup this folder after update copy to the new version again. :)
Postby developer » Sat Jan 24, 2015 8:16 pm
Some button like stream is in Chinese instead of english. Please fix this for all screens
UDP and RTP in DVBlast doesnt work.. Good thing is some channels which were not coming up in older version due to some naming issues,are coming up in new firmware . But no stream works in dvlast in .0.5
WIFI password option is still now there and some how both Lan and wifi should work at same time.Not that one should get disconnected when other is connected .
My RTP and UDP doesnt work at all now. Tried reverting back to .0.3 but still no use.
Tried VDR and Intelsat 66 E is there but even if i select C band ,nothing gets scanned and the frequencies look for KU band.
It should change to C band freq since we cannot edit high and low freq.It also looks like Vertical and Horiz are working for opposite voltages.
developer
Re: MOI Pro Firmware V1.0.0.5 is released.
Postby developer » Sun Jan 25, 2015 2:08 am
Good to have: Please include all version of kernel,firmware and anything else to be shown on web page in next release. Also need a factory reset for reset all config files in case there is some error .. Wifi WPA2 support is also needed. Open wifi without password is of no use...Add Hard ware version ,MAC of wifi and Lan , gateway ,Time and to change tume, Display Resolution for HDMI , Not sure if we can control volume if hdmi works , so on in the about screen also and may be check for update which will alow users to check for firmware update thru webpage.
developer
Return to MOI Pro
