problem about tbs6982 and mumudvb
Postby tyrissac » Tue Apr 21, 2015 3:57 pm
I use card tbs6982 and mumudvb base on ubuntu 12.04 to make IPTV system.
parameters of Satellite :
Satellite Ku_NEW_SAT(138.0E)
Transpander 12472/V/33500/Auto
LNB Frequency 11300
LNB Power 13V/18V
DiSEqC1.0 None
DiSEqC1.1 None
22KHz Auto
Here is my mumudvb config:
card=1
tuner=0
freq=11300
srate=12472
pol=v
switch_type=u
Driver of the card was workding.
I run mumudvd and i cannot found the signal .
the error log :
Code: Select all
[email protected]:/home/isaac/yhplayground/mumudvb# mumudvb -d -c  conf/mumu.conf
MuMuDVB Version 2.0.0_20150103_mumudvb2
 --- Build information ---
Built with CAM support.
Built without SCAM support.
Built with ATSC support.
Built with ATSC long channel names support.
Built with support for DVB API Version 5.4.
Built with support for DVB-T2.
Originally based on dvbstream 0.6 by (C) Dave Chapman 2001-2004
Released under the GPL.
Latest version available from http://mumudvb.braice.net/
Project from the [email protected] (http://www.crans.org)
by Brice DUBOST ([email protected])
Info:  Main:  Autoconfiguration, we activate SAP announces. if you want to disable them see the README.
Info:  Main:  Autoconfiguration, we activate PAT rewriting. if you want to disable it see the README.
Info:  Main:  Autoconfiguration, we activate SDT rewriting. if you want to disable it see the README.
Info:  Main:  ========== End of configuration, MuMuDVB version 2.0.0_20150103_mumudvb2 is starting ==========
Info:  Main:  Streaming. Freq 11300000
Info:  Tune:  Using DVB card "TurboSight TBS 6982SE DVBS/S2 frontend" tuner 0
Info:  Tune:  Tuning DVB-S to Freq: 1550000 kHz, LO frequency 9750000 kHz Pol:V Srate=12472000, LNB number: 0
Info:  Tune:  LNB voltage 13V
Info:  Tune:  DISEQC SETTING SUCCEDED
Info:  Tune:  FE_STATUS:
Info:  Main:  Card not tuned after timeout - exiting
tyrissac
Re: problem about tbs6982 and mumudvb
Postby tyrissac » Tue Apr 21, 2015 4:00 pm
How can I fix that ? help help help.....
I guess my configure file is wrong
thx for all,sorry for bad english
tyrissac
Return to General discussion
