TBS7220 - Not working - No driver
Postby xtraya » Fri Jun 26, 2015 5:28 am
Hello TBS
I bought few days ago on ebay brand new TBS7220 card, and tryed to install it into miniPCIe slot of INTEL NUC device.
When i powered it up, card is not avaiable, neither in
BIOS (on intel NUC devices you can see actual miniPCIe card installed)
nor in linux (Ubunutu 14.04 64bit) where when i try with
lspci -v
there is no Multimedia Controler response. Does card have some special requests (ex. voltage use , total power consumption , etc...)
btw. when linux driver will be avaiable for this model? there is no 7220 file inside of driver archive.
Do you have any idea?
xtraya
Re: TBS7220 - Not working - No driver
Postby steven » Mon Jul 20, 2015 5:49 pm
Hi xtraya
Please have a try check your BIOS setting about PCIE link speed? If it set to Auto,please change it to Gen1.
and you can have a try change the PCI-E slot.
Return to DVB-T2/T/C TV Tuner mini PCIe Card TBS7220
