CI PLUS
CI PLUS
Postby tonyfulls » Mon Oct 26, 2015 4:19 pm
Do you plan to support CI+ interface?
tonyfulls
Re: CI PLUS
Postby steven » Tue Oct 27, 2015 6:15 pm
Maybe you can have a look at http://www.unicam2.to/
and for CI+ need the CI+ license,if we can get this we will add CI+ support. :)
Re: CI PLUS
Postby tonyfulls » Tue Oct 27, 2015 8:12 pm
tricolor tv card's not work with unicam because dre crypt 3.0/ADEC, they ci+ cam not work in backward compatibility mode.
tonyfulls
Re: CI PLUS
Postby minhasp » Mon Aug 07, 2017 4:06 pm
steven wrote:Hi
Does TBS5881 work with UniCam,
minhasp
Re: CI PLUS
Postby steven » Mon Aug 07, 2017 4:13 pm
should be ok but you need to have a try :)
Re: CI PLUS
Postby minhasp » Mon Aug 07, 2017 7:16 pm
steven wrote:should be ok but you need to have a try :)
where I can buy that one,
in http://www.unicam2.to/
only for download software
minhasp
