- Code: Select all
uname -a
Linux dvb6new 2.6.39-ARCH #1 SMP PREEMPT Sat Jul 9 14:57:41 CEST 2011 x86_64 AMD Athlon(tm) 64 Processor 3000+ AuthenticAMD GNU/Linux
Two cards installed: TBS6984 and TBS6981.
Actions order:
1.Download linux-tbs-drivers_110806 from official site.
2.Unpacking, running v4l/tbs-x86_64.sh, make, make install.
"Make" completes ok with message "found 438 modules". "Make install" completes ok too.
3.Rebooting...
- Code: Select all
[[email protected] ~]# dmesg |grep DVB
[ 5.083568] DVB: registering new adapter (SAA716x dvb adapter)
[ 5.265024] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 5.265297] DVB: registering new adapter (SAA716x dvb adapter)
[ 5.289115] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 5.289678] DVB: registering new adapter (SAA716x dvb adapter)
[ 5.312618] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 5.313013] DVB: registering new adapter (SAA716x dvb adapter)
[ 5.351931] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
- Code: Select all
[[email protected] ~]# ls /dev/dvb/
adapter0 adapter1 adapter2 adapter3
Any info about TBS6981 wasn't found in dmesg.
What i found in "lspci -v":
- Code: Select all
02:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 02)
Subsystem: Device 6984:0013
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at dc200000 (64-bit, non-prefetchable) [size=1M]
Capabilities: [50] Express Endpoint, MSI 00
Capabilities: [100] Vendor Specific Information: ID=0000 Rev=0 Len=088 <?>
Kernel modules: saa716x_tbs-dvb
03:00.0 Multimedia video controller: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder (rev 04)
Subsystem: Device 6981:8888
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at dc000000 (64-bit, non-prefetchable) [size=2M]
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [90] Vital Product Data
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [100] Advanced Error Reporting
Capabilities: [200] Virtual Channel
Kernel modules: cx23885
4.Let's assume that TBS6984 is working ok. Triing to scan with scan-s2... Using such file for Asiasat5 (100.5E):
- Code: Select all
S2 3794000 H 4640000 AUTO
S1 3960000 H 27500000 AUTO
S1 4000000 H 28125000 AUTO
I was triing on all adapters (0-3), using C-MULTI and C-BAND lnb-type, but everytime i received messages like "WARNING: >>> tuning failed!!!" or "WARNING: filter timeout for pid 0x0011".
And after every run of scan-s2 there was new messages in "dmesg":
- Code: Select all
[ 713.869230] TurboSight TBS 6984 Frontend:
[ 713.869233] tbs6984fe - delivery system -1 is not supported
What's problem?!
