[ Moderator Control Panel ]
by nayton » Tue Dec 01, 2015 10:45 pm
Hello
Is it possible to install 6205 (dvb-c mode) to system where 6905 (s2) already installed and working? I try to add some cable channels on my satellite system. It is TVHeadend on Ubuntu 14.04.
nayton
by squirrely » Sun Dec 04, 2016 5:50 am
I'm also interested in the same thing. I just need to run two separate 6205 cards in C and T modes on a single machine.
squirrely
by steven » Fri Dec 16, 2016 11:15 am
No problem with latest open source driver you can using DVB-C and DVB-T ,DVB-S at the same time
so use mix with 6205 and 6905 no problem
For 6205 you can check this guide :
http://www.tbsiptv.com/download/tbs6205 ... _guide.pdfThanks
by squirrely » Fri Dec 16, 2016 4:56 pm
Thanks, steven! I was about to setup virtual machines and use PCI passthrough as workaround, but I'll try your approach. Way to go TBS!
squirrely
by squirrely » Wed Jan 25, 2017 12:42 am
Hi, I think I've missed the main thing here when you said you can mix 6205 with 6905. What if I have 4x6205's ? Is there some easy solution to run say 3 cards in DVB-C mode and one in DVB-T ?
squirrely
by squirrely » Wed Mar 01, 2017 2:16 pm
Hi!
Thanks, steven, I've done it and have everything successfully running for some time now.
squirrely
