Dvblast->dvb-s2(8PSK)->TS discontinuity...
Postby marian34 » Thu Dec 03, 2015 9:18 pm
Code: Select all
~$ szap-s2 -c dvb/dvb_s/channels.conf ct1hd -M 5 -S 1
reading channels from file 'dvb/dvb_s/channels.conf'
zapping to 29 'CT1HD':
delivery DVB-S2, modulation 8PSK
sat 0, frequency 12363 MHz V, symbolrate 29500000, coderate auto, rolloff 0.35
vpid 0x1393, apid 0x139d, sid 0x1325
status 1f | signal 7c17 | snr ffff | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal cbeb | snr ffff | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal cc4b | snr ffff | ber 00000000 | unc 00000000 | FE_HAS_LOCK
Code: Select all
~$ dvblast -f -
DVBlast 3.0 (release)
warning: restarting
debug: compiled with DVB API version 5.3
debug: CA interface with 1 slot
debug:   CI link layer level interface type
debug:   0 available descramblers (keys)
CAM none
debug: setting filter on PID 0
debug: setting filter on PID 16
debug: setting filter on PID 17
debug: setting filter on PID 18
debug: setting filter on PID 19
debug: setting filter on PID 20
error: no config file
warning: TS discontinuity on pid   18 expected_cc 10 got 11 (EPG, sid 0)
warning: TS discontinuity on pid   18 expected_cc  5 got  6 (EPG, sid 0)
Code: Select all
~$ uname -a
Linux marian-lubuntu 3.16.0-23-generic #31-Ubuntu SMP Tue Oct 21 18:00:35 UTC 2014 i686 athlon i686 GNU/Linux
Code: Select all
~$ lscpu
Architecture:          i686
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                2
On-line CPU(s) list:   0,1
Thread(s) per core:    1
Core(s) per socket:    2
Socket(s):             1
Vendor ID:             AuthenticAMD
CPU family:            20
Model:                 1
Model name:            AMD E-350 Processor
Stepping:              0
CPU MHz:               800.000
CPU max MHz:           1600,0000
CPU min MHz:           800,0000
BogoMIPS:              3200.05
Virtualization:        AMD-V
L1d cache:             32K
L1i cache:             32K
L2 cache:              512K
The card is functional - tested in Windows 7.
Driver is http://www.tbsdtv.com/download/ .
How would you proceed to eliminate this problem?
marian34
Re: Dvblast->dvb-s2(8PSK)->TS discontinuity...
Postby marian34 » Thu Dec 10, 2015 5:29 am
It's about problem drivers.Tested with dvblast, mumudvb, vdr.
In Windows, this phenomenon shows after breaking up with linux distro after reboot.Otherwise, the windows ok.
Maybe it is a parameter "pilot", which Linux driver can not switch ???
marian34
Postby marian34 » Fri Dec 11, 2015 7:22 pm
Yet few remarks:
-parameter "pilot" does not matter
-it does not apply to all DVB-S2 transp.
-maybe non-standard PAT(EIT):
Code: Select all
~$ dvblast -f 12363000
warning: TS discontinuity on pid   18 expected_cc 15 got  0 (EPG, sid 0)
warning: TS discontinuity on pid   18 expected_cc  7 got  8 (EPG, sid 0)
warning: invalid EIT section received on PID 18
error type: invalid_eit_section pid: 18
warning: TS discontinuity on pid   18 expected_cc  2 got  3 (EPG, sid 0)
marian34
