Is there any way to compile QBOX2 for arm processor
Postby t2i8 » Sun Dec 06, 2015 6:54 am
I have a QBOX S2 which I have confirmed works with a Windows OS. I would like to use the USB adapter on an ARM based synology DS213j NAS unit. It there a method to compile the drivers for arm operation?
t2i8
Re: Is there any way to compile QBOX2 for arm processor
Postby t2i8 » Tue Dec 08, 2015 2:08 am
Thanks crazycat,
Unfortunately I get the following output when running make:
make
make -C /media_build/v4l
make[1]: Entering directory `/media_build/v4l'
scripts/make_makefile.pl
make[1]: scripts/make_makefile.pl: Command not found
Updating/Creating .config
make[2]: Entering directory `/media_build/linux'
/bin/sh: ./patches_for_kernel.pl: not found
Version 3.2.40 not supported
/bin/sh: exit: line 30: Illegal number: -1
make[2]: *** [apply_patches] Error 2
make[2]: Leaving directory `/media_build/linux'
/bin/sh: ./scripts/make_kconfig.pl: not found
make[1]: *** No rule to make target `.config', needed by `.myconfig'. Stop.
make[1]: Leaving directory `/media_build/v4l'
make: *** [all] Error 2
Is there further actions I can take to fix the install issue.
t2i8
