nand errors
nand errors
Postby reneroger » Sat Jan 30, 2016 6:15 pm
I see errors in the dmesg of my MOI Box:
Code: Select all
[42387.790000] s3c-nand: 1 bit error detected at byte 138, correcting from 0x61 to 0x69...OK
[90792.625000] s3c-nand: 1 bit error detected at byte 91, correcting from 0x6b to 0x6f...OK
[699615.240000] s3c-nand: 1 bit error detected at byte 138, correcting from 0x66 to 0x6e...OK
Is the on board nand flash dying?
What can I do - can I boot from a SD Card or USB Flash drive?
Roger
reneroger
Return to General discussion
